이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Push both tabs away from the center of the device.
While both are in the fully unlocked position, slide the battery out.
Turn the laptop over and open it so that you can see the keyboard and screen.
Using a Phillips #000 screwdriver, remove the two 4 mm Phillips #8 screws that are under the black covers on the front of your screen.
Insert the plastic opening tool into the seam on the top of the screen.
Use the plastic opening tool to pop open the clasps that keep the casing on the screen.
Follow this seam around the laptop's screen with the plastic opening tool until the plastic cover comes off.
Using a Phillips #000 screwdriver, remove the top two 4 mm Phillips #8 screws that join the LCD screen to the plastic casing.
Using the same screwdriver, remove the bottom four 4 mm Phillips #8 screws that mount the screen onto the base of the laptop.
Gently lay the LCD on the keyboard, and lay down the back panel of the screen as well. They are not attached and will separate easily.
Remove the tape that secures the video connector to the LCD.
While maintaining a firm grip on the LCD, grasp the video connector at its base, and pull it away from you.
다른 10명이 해당 안내서를 완성하였습니다.
