주요 콘텐츠로 건너뛰기
Samsung NP305E5A-A03US RAM Replacement
필요한 것
  1. Samsung NP305E5A-A03US RAM Replacement, Hard Drive: 1 단계, 이미지 1개 중 1개
    • Unscrew the 3.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
  2. Samsung NP305E5A-A03US RAM Replacement: 2 단계, 이미지 1개 중 1개
    • Wedge the plastic opening tool between the L-shaped back panel to slide the panel off.
    • Note this may take force. If you have difficulties using the plastic opening tool, try to use your hands to pull the panel off.
  3. Samsung NP305E5A-A03US RAM Replacement: 3 단계, 이미지 2개 중 1개 Samsung NP305E5A-A03US RAM Replacement: 3 단계, 이미지 2개 중 2개
    • Pull the panel towards you to remove the panel.
  4. Samsung NP305E5A-A03US RAM Replacement: 4 단계, 이미지 1개 중 1개
    • Unscrew the three 3.5mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
    • Unscrew the one 4.45mm screws using a Phillips J0 Screwdriver by rotating the screwdriver in the counter clockwise direction.
  5. Samsung NP305E5A-A03US RAM Replacement: 5 단계, 이미지 2개 중 1개 Samsung NP305E5A-A03US RAM Replacement: 5 단계, 이미지 2개 중 2개
    • Pull the cord that connects the Hard Drive to the Motherboard to disconnect it.
  6. Samsung NP305E5A-A03US RAM Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the Hard Drive by lifting it towards you.
  7. Samsung NP305E5A-A03US RAM Replacement, RAM: 7 단계, 이미지 1개 중 1개
    • Place your thumbs on the metal tabs.
    • Push outwards on the metal tabs to release the RAM.
  8. Samsung NP305E5A-A03US RAM Replacement: 8 단계, 이미지 2개 중 1개 Samsung NP305E5A-A03US RAM Replacement: 8 단계, 이미지 2개 중 2개
    • Pull out the RAM towards you to remove it from the laptop.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Julia Dotter
회원 가입일: 10/31/16
224 평판
안내서 1개를 작성함
Baylor, Team 5-7, Williams Fall 2016 Baylor, Team 5-7, Williams Fall 2016 회원
BU-WILLIAMS-F16S5G7
3 회원들
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 8
전체 시간: 471
