주요 콘텐츠로 건너뛰기
Samsung NP305V5A Motherboard Replacement
필요한 것
  1. Samsung NP305V5A Motherboard Replacement, Remove battery: 1 단계, 이미지 1개 중 1개
    • At least this part is easy. Simply push both tabs outwards, away from the center of the laptop, let go, and push/pull the battery out.
  2. Samsung NP305V5A Motherboard Replacement, Remove rubber feet and the screws under them: 2 단계, 이미지 1개 중 1개
    • Annoyingly, in many newer laptops, screws are hidden under the rubber feet. This is one of them. Only the circled rubber feet have screws under them, the fourth one does not. Pry them off.
  3. Samsung NP305V5A Motherboard Replacement, Remove memory door & screws: 3 단계, 이미지 2개 중 1개 Samsung NP305V5A Motherboard Replacement, Remove memory door & screws: 3 단계, 이미지 2개 중 2개
    • Remove the single screw from the memory door, and pry the door up.
    • Remove the single screw under the memory door.
  4. Samsung NP305V5A Motherboard Replacement, Remove bottom cover: 4 단계, 이미지 1개 중 1개
    • With the laptop's battery area facing away from you, pull the bottom cover towards you. It will slide towards you.
    • Pull the cover upwards, and it will come off.
  5. Samsung NP305V5A Motherboard Replacement, Remove hard drive & palmrest screws: 5 단계, 이미지 2개 중 1개 Samsung NP305V5A Motherboard Replacement, Remove hard drive & palmrest screws: 5 단계, 이미지 2개 중 2개
    • Remove the four Philips screws securing the hard drive.
    • Remove the twelve Philips screws securing the palmrest.
    • Remove the single Philips screw securing the disc drive.
    • Pull upwards on the caddy's tab.
    • Pull the connector away from the caddy, and set the hard drive aside.
  6. Samsung NP305V5A Motherboard Replacement, Remove base: 6 단계, 이미지 1개 중 1개
    • Use a guitar pick to separate the base from the palmrest.
    • This type of laptop is the kind that the motherboard is attached to the palmrest, rather than the base, and so, the base comes off.
  7. Samsung NP305V5A Motherboard Replacement, Remove heatsink screws, hinge screws & more: 7 단계, 이미지 1개 중 1개
    • Remove the four heatsink screws surrounding the CPU socket. This is necessary as the heatsink blocks the hinges from being removed.
    • Remove the 7 Philips screws securing the hinges to the palmrest.
    • Turn the hinges away from the palmrest. You may need to use a screwdriver to pry, but be careful if you do!
    • Remove the antenna connectors from the Wi-Fi card.
    • Remove all of the shown connectors. Remove the motherboard screw hidden by the video cable. You'll have to break out the Philips #0 bit for this, if you haven't already.
    • Remove the three remaining motherboard screws.
  8. Samsung NP305V5A Motherboard Replacement, Remove motherboard: 8 단계, 이미지 1개 중 1개
    • At this point, the motherboard should just lift out. If not, check carefully for cables or screws you may have forgotten to undo.
    • Now you're done! In this laptop's case, the DC jack is the problem, but I'm not going to go over that because there are other howtos on the Internet on DC jack replacement.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Joseph Sctbunio
회원 가입일: 09/23/17
7,767 평판
안내서 42개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 12
지난 30일: 28
전체 시간: 3,490
