주요 콘텐츠로 건너뛰기
Samsung NP350E5C-A02US RAM Replacement
필요한 것
  1. Samsung NP350E5C-A02US RAM Replacement, Battery: 1 단계, 이미지 1/1
    • Lay the laptop down so that the bottom is facing up.
    • There is no battery in the picture.
  2. Samsung NP350E5C-A02US RAM Replacement: 2 단계, 이미지 1/1
    • Slide the two plastic tabs to the opposing sides.
  3. Samsung NP350E5C-A02US RAM Replacement: 3 단계, 이미지 1/1
    • While both are in the unlocked position, slide the battery out.
  4. Samsung NP350E5C-A02US RAM Replacement, Hard drive and memory stick cover: 4 단계, 이미지 1/1
    • Remove the M2.5x5 mm screw with a Phillips #0 screwdriver.
  5. Samsung NP350E5C-A02US RAM Replacement: 5 단계, 이미지 1/1
    • Slide the cover 1/4" towards the front of the laptop.
  6. Samsung NP350E5C-A02US RAM Replacement: 6 단계, 이미지 1/1
    • Then, lift the cover off.
  7. Samsung NP350E5C-A02US RAM Replacement, RAM: 7 단계, 이미지 1/1
    • Gently push the lock springs outwards and the RAM stick will rise when it's free.
  8. Samsung NP350E5C-A02US RAM Replacement: 8 단계, 이미지 1/1
    • Then, gently pull the RAM stick towards the front of the laptop.
  9. Samsung NP350E5C-A02US RAM Replacement: 9 단계, 이미지 1/1
    • Repeat the last two steps for the second RAM stick if needed.
결론
James Kingrey
회원 가입일: 10/04/18
775 평판
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 7
30일 전: 13
전체 시간: 260
