주요 콘텐츠로 건너뛰기
Samsung NP350E5C-A02US Wifi card Replacement
필요한 것
  1. Samsung NP350E5C-A02US Wifi card Replacement, Battery: 1 단계, 이미지 1/1
    • Lay the laptop down so that the bottom is facing up.
    • There is no battery in the picture.
  2. Samsung NP350E5C-A02US Wifi card Replacement: 2 단계, 이미지 1/1
    • Slide the two plastic tabs to the opposing sides.
  3. Samsung NP350E5C-A02US Wifi card Replacement: 3 단계, 이미지 1/1
    • While both are in the unlocked position, slide the battery out.
  4. Samsung NP350E5C-A02US Wifi card Replacement, Wifi card: 4 단계, 이미지 1/1
    • Look for the compartment with the Wifi symbol on it.
  5. Samsung NP350E5C-A02US Wifi card Replacement: 5 단계, 이미지 1/1
    • Using a Phillips #1 screwdriver, remove the 5 mm screw located beside the Wifi symbol.
  6. Samsung NP350E5C-A02US Wifi card Replacement: 6 단계, 이미지 1/1
    • Gently pry up cover using a plastic spudger or opening tool.
  7. Samsung NP350E5C-A02US Wifi card Replacement: 7 단계, 이미지 1/1
    • Gently remove the two wires attached to the Wifi card by using a plastic opening tool or plastic spudger to pry up from under where the wire is attached.
  8. Samsung NP350E5C-A02US Wifi card Replacement: 8 단계, 이미지 1/1
    • Using the Phillips #0 screwdriver, remove the M2.5x3 mm screw holding in the Wifi card.
  9. Samsung NP350E5C-A02US Wifi card Replacement: 9 단계, 이미지 1/1
    • Gently pull out the Wifi card.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
James Kingrey
회원 가입일: 10/04/18
775 평판
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 10
30일 전: 21
전체 시간: 255
