주요 콘텐츠로 건너뛰기
Samsung NP350V5C-T02US Wifi card Replacement
필요한 것
  1. Samsung NP350V5C-T02US Wifi card Replacement, Wifi card: 1 단계, 이미지 1/1
    • Flip over the laptop so you are facing the backside.
  2. Samsung NP350V5C-T02US Wifi card Replacement: 2 단계, 이미지 1/3 Samsung NP350V5C-T02US Wifi card Replacement: 2 단계, 이미지 2/3 Samsung NP350V5C-T02US Wifi card Replacement: 2 단계, 이미지 3/3
    • Look for the compartment with the Wifi symbol on it.
    • Using the Phillips #1 screwdriver remove the M2.5X5 screw, located beside the Wifi Symbol.
    • Using the plastic spudger, carefully pry the Wifi panel off.
  3. Samsung NP350V5C-T02US Wifi card Replacement: 3 단계, 이미지 1/2 Samsung NP350V5C-T02US Wifi card Replacement: 3 단계, 이미지 2/2
    • Gently remove the two wires attached to the the Wifi card by using the plastic spudger to pry from underneath the attachment points.
    • Using the #2 Phillips screwdriver, remove the M2.5X3 mm screw holding in the Wifi card
  4. Samsung NP350V5C-T02US Wifi card Replacement: 4 단계, 이미지 1/2 Samsung NP350V5C-T02US Wifi card Replacement: 4 단계, 이미지 2/2
    • Using you hand, gently pull out the Wifi card.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Syed Asad
회원 가입일: 09/25/17
240 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 13
전체 시간: 995
