소개
The display screen is a main part of any laptop and without it the computer would be useless. This guide will show users how to replace the display screen.
필요한 것
Turn the computer off.
Disconnect the charging cable from the laptop.
Flip the laptop face down on a flat surface.
Open the laptop.
Locate the two (2) screw covers.
Remove the screw covers with the metal spudger.
Locate the six (6) 2.39 mm screws on the display bracket.
Remove the four (4) screws on the left and right sides of the display bracket located near the base of the display with the Philips #0 screwdriver.
Remove the two (2) screws on the left and right sides of the display bracket located near the top of the display with the Phillips #0 screwdriver.
다른 한 분이 해당 안내서를 완성하였습니다.
