주요 콘텐츠로 건너뛰기
Samsung NP510R5E-A01UB Hard Drive Replacement
필요한 것
  1. Samsung NP510R5E-A01UB Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/1
    • Make sure the device is powered off before beginning.
    • Using the Phillips #0 screwdriver, remove the 6.5mm long screw in the area circled.
  2. Samsung NP510R5E-A01UB Hard Drive Replacement: 2 단계, 이미지 1/1
    • With the cover removed, unscrew all four of the 4.75mm long screws using the Phillips #0 screwdriver.
  3. Samsung NP510R5E-A01UB Hard Drive Replacement: 3 단계, 이미지 1/2 Samsung NP510R5E-A01UB Hard Drive Replacement: 3 단계, 이미지 2/2
    • Unplug the connector from the hard drive by pulling straight out.
결론
Brian Briggs
회원 가입일: 02/14/18
529 평판
안내서 4개 작성하였습니다
USF Tampa, Team S6-G5, Eyestone Spring 2018 USF Tampa, Team S6-G5, Eyestone Spring 2018 회원
USFT-EYESTONE-S18S6G5
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 16
전체 시간: 477
