소개
The motherboard connects all components that make the computer work. If it's damaged it will need to be replaced. This guide will show you how to remove it.
필요한 것
Lightly press down on the the back panel and pull away from the back case. The panel should slide away and detach from the back case.
Using the Phillips #0 screwdriver, remove the 6.5mm long screw in the area circled.
Remove the two rubber feet with arrows by them on the back side to uncover two screws.
Unscrew the four silver 4.4mm long screws near the hard drive.
Unscrew the remaining nine black 6.5mm long screws. Then remove the back casing using a pry tool if needed.
다른 한 분이 해당 안내서를 완성하였습니다.
