주요 콘텐츠로 건너뛰기
Samsung NP510R5E-A01UB Speaker Replacement
필요한 것
  1. Samsung NP510R5E-A01UB Speaker Replacement, Hard Drive: 1 단계, 이미지 1/1
    • Make sure the device is powered off before beginning.
    • Using the Phillips #0 screwdriver, remove the 6.5mm long screw in the area circled.
  2. Samsung NP510R5E-A01UB Speaker Replacement: 2 단계, 이미지 1/1
    • With the cover removed, unscrew all four of the 4.75mm long screws using the Phillips #0 screwdriver.
  3. Samsung NP510R5E-A01UB Speaker Replacement: 3 단계, 이미지 1/2 Samsung NP510R5E-A01UB Speaker Replacement: 3 단계, 이미지 2/2
    • Unplug the connector from the hard drive by pulling straight out.
  4. Samsung NP510R5E-A01UB Speaker Replacement, Speaker: 4 단계, 이미지 1/3 Samsung NP510R5E-A01UB Speaker Replacement, Speaker: 4 단계, 이미지 2/3 Samsung NP510R5E-A01UB Speaker Replacement, Speaker: 4 단계, 이미지 3/3
    • Remove the two rubber feet with arrows by them on the back side to uncover two screws.
    • Unscrew the four silver 4.4mm long screws near the hard drive.
    • Unscrew the remaining nine black 6.5mm long screws. Then remove the back casing using a pry tool if needed.
  5. Samsung NP510R5E-A01UB Speaker Replacement: 5 단계, 이미지 1/2 Samsung NP510R5E-A01UB Speaker Replacement: 5 단계, 이미지 2/2
    • Untangle the wires attached to the exterior of the right speaker.
    • Lift the tape up holding the wires down to fully release the wires.
  6. Samsung NP510R5E-A01UB Speaker Replacement: 6 단계, 이미지 1/1
    • Unscrew the 3.4mm long screw holding the right speaker in place.
  7. Samsung NP510R5E-A01UB Speaker Replacement: 7 단계, 이미지 1/1
    • Pull up on the wires circled to disconnect the right speaker.
  8. Samsung NP510R5E-A01UB Speaker Replacement: 8 단계, 이미지 1/1
    • Using the plastic opening tool, pry up the right speaker and take it out.
  9. Samsung NP510R5E-A01UB Speaker Replacement: 9 단계, 이미지 1/1
    • Unscrew the 3.4mm long screw holding the left speaker in place.
  10. Samsung NP510R5E-A01UB Speaker Replacement: 10 단계, 이미지 1/1
    • Pull up on the wires to disconnect the left speaker.
  11. Samsung NP510R5E-A01UB Speaker Replacement: 11 단계, 이미지 1/1
    • Using the plastic opening tool, pry up the left speaker and take it out.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Brian Briggs
회원 가입일: 02/14/18
529 평판
안내서 4개 작성하였습니다
USF Tampa, Team S6-G5, Eyestone Spring 2018 USF Tampa, Team S6-G5, Eyestone Spring 2018 회원
USFT-EYESTONE-S18S6G5
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 13
전체 시간: 241
