주요 콘텐츠로 건너뛰기
Samsung NP540U3C-A02UB Battery Replacement
필요한 것
  1. Samsung NP540U3C-A02UB Battery Replacement, Hard Drive: 1 단계, 이미지 1/1
    • Turn off the laptop before beginning disassembly and unplug it from the power cord.
    • Place the laptop flat with its bottom facing up.
  2. Samsung NP540U3C-A02UB Battery Replacement: 2 단계, 이미지 1/2 Samsung NP540U3C-A02UB Battery Replacement: 2 단계, 이미지 2/2
    • Remove one 4 mm Phillips #00 screw labeled "HDD Memory".
  3. Samsung NP540U3C-A02UB Battery Replacement: 3 단계, 이미지 1/3 Samsung NP540U3C-A02UB Battery Replacement: 3 단계, 이미지 2/3 Samsung NP540U3C-A02UB Battery Replacement: 3 단계, 이미지 3/3
    • Gently release the 3 clips holding the HDD cover with the plastic opening tool.
    • Remove the HDD cover from the device.
  4. Samsung NP540U3C-A02UB Battery Replacement: 4 단계, 이미지 1/2 Samsung NP540U3C-A02UB Battery Replacement: 4 단계, 이미지 2/2
    • Remove the four 6 mm Phillips #00 screws attaching the hard drive to the case.
  5. Samsung NP540U3C-A02UB Battery Replacement: 5 단계, 이미지 1/2 Samsung NP540U3C-A02UB Battery Replacement: 5 단계, 이미지 2/2
    • Using the plastic opening tool, push the hard drive connector clip upwards in order to release the cable.
  6. Samsung NP540U3C-A02UB Battery Replacement: 6 단계, 이미지 1/2 Samsung NP540U3C-A02UB Battery Replacement: 6 단계, 이미지 2/2
    • Remove the hard drive from the case.
  7. Samsung NP540U3C-A02UB Battery Replacement, Battery: 7 단계, 이미지 1/2 Samsung NP540U3C-A02UB Battery Replacement, Battery: 7 단계, 이미지 2/2
    • Remove the following screws holding the case together:
    • 6x 4mm Phillips #00 screws.
    • 3x 6mm Phillips #00 screws.
  8. Samsung NP540U3C-A02UB Battery Replacement: 8 단계, 이미지 1/2 Samsung NP540U3C-A02UB Battery Replacement: 8 단계, 이미지 2/2
    • Using the opening tool, remove the two rubber pads just above the hard drive cover.
  9. Samsung NP540U3C-A02UB Battery Replacement: 9 단계, 이미지 1/2 Samsung NP540U3C-A02UB Battery Replacement: 9 단계, 이미지 2/2
    • Remove the 2x 4mm Phillips #00 screws formerly concealed by the pads.
  10. Samsung NP540U3C-A02UB Battery Replacement: 10 단계, 이미지 1/1
    • Using the plastic opening tool, gently lift and remove the back cover.
    • There are clips along the edges of the back cover that hold it in place. Be careful not to break these.
  11. Samsung NP540U3C-A02UB Battery Replacement: 11 단계, 이미지 1/2 Samsung NP540U3C-A02UB Battery Replacement: 11 단계, 이미지 2/2
    • Using your hands or the plastic opening tool, gently remove the tape holding the wires in place.
  12. Samsung NP540U3C-A02UB Battery Replacement: 12 단계, 이미지 1/3 Samsung NP540U3C-A02UB Battery Replacement: 12 단계, 이미지 2/3 Samsung NP540U3C-A02UB Battery Replacement: 12 단계, 이미지 3/3
    • Remove the 4x 4mm Phillips #00 screws securing the battery to the chassis.
  13. Samsung NP540U3C-A02UB Battery Replacement: 13 단계, 이미지 1/2 Samsung NP540U3C-A02UB Battery Replacement: 13 단계, 이미지 2/2
    • Using the plastic opening tool, gently pull the battery connector towards the battery to disconnect it.
  14. Samsung NP540U3C-A02UB Battery Replacement: 14 단계, 이미지 1/1
    • Remove the battery from the laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Alejandro
회원 가입일: 03/28/22
253 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team C-1, Gurgel Spring 2022 UMass Dartmouth, Team C-1, Gurgel Spring 2022 회원
UMASSD-GURGEL-S22SCG1
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 13
30일 전: 33
전체 시간: 891
