주요 콘텐츠로 건너뛰기
Samsung NP540U3C-A02UB Fan Replacement
필요한 것
  1. Samsung NP540U3C-A02UB Fan Replacement, Fan: 1 단계, 이미지 1/1
    • Turn off the laptop and disconnect from the charging cable before beginning disassembly.
    • Place the laptop flat with its bottom facing up.
  2. Samsung NP540U3C-A02UB Fan Replacement: 2 단계, 이미지 1/2 Samsung NP540U3C-A02UB Fan Replacement: 2 단계, 이미지 2/2
    • Remove the 1x 4mm Phillips #00 screw labeled "HDD Memory".
  3. Samsung NP540U3C-A02UB Fan Replacement: 3 단계, 이미지 1/3 Samsung NP540U3C-A02UB Fan Replacement: 3 단계, 이미지 2/3 Samsung NP540U3C-A02UB Fan Replacement: 3 단계, 이미지 3/3
    • Gently release the three clips holding the HDD cover with the plastic opening tool.
    • Remove the HDD cover from the device.
  4. Samsung NP540U3C-A02UB Fan Replacement: 4 단계, 이미지 1/1
    • Peel the yellow tape up so it no longer blocks the fan's wires and screw.
  5. Samsung NP540U3C-A02UB Fan Replacement: 5 단계, 이미지 1/1
    • Remove the two 2.4mm Phillips #00 screws attaching the fan to the case.
    • Remove the two 6mm Phillips #00 screws attaching the fan to the case.
  6. Samsung NP540U3C-A02UB Fan Replacement: 6 단계, 이미지 1/2 Samsung NP540U3C-A02UB Fan Replacement: 6 단계, 이미지 2/2
    • Using the plastic opening tool, gently disconnect the fan from the motherboard by unplugging the wire.
  7. Samsung NP540U3C-A02UB Fan Replacement: 7 단계, 이미지 1/1
    • Remove the fan from the case.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Colby Bolger
회원 가입일: 03/28/22
277 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team C-1, Gurgel Spring 2022 UMass Dartmouth, Team C-1, Gurgel Spring 2022 회원
UMASSD-GURGEL-S22SCG1
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 11
전체 시간: 262
