주요 콘텐츠로 건너뛰기
Samsung NP540U3C-A02UB Hard Drive Replacement
필요한 것
  1. Samsung NP540U3C-A02UB Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/1
    • Turn off the laptop before beginning disassembly and unplug it from the power cord.
    • Place the laptop flat with its bottom facing up.
  2. Samsung NP540U3C-A02UB Hard Drive Replacement: 2 단계, 이미지 1/2 Samsung NP540U3C-A02UB Hard Drive Replacement: 2 단계, 이미지 2/2
    • Remove one 4 mm Phillips #00 screw labeled "HDD Memory".
  3. Samsung NP540U3C-A02UB Hard Drive Replacement: 3 단계, 이미지 1/3 Samsung NP540U3C-A02UB Hard Drive Replacement: 3 단계, 이미지 2/3 Samsung NP540U3C-A02UB Hard Drive Replacement: 3 단계, 이미지 3/3
    • Gently release the 3 clips holding the HDD cover with the plastic opening tool.
    • Remove the HDD cover from the device.
  4. Samsung NP540U3C-A02UB Hard Drive Replacement: 4 단계, 이미지 1/2 Samsung NP540U3C-A02UB Hard Drive Replacement: 4 단계, 이미지 2/2
    • Remove the four 6 mm Phillips #00 screws attaching the hard drive to the case.
  5. Samsung NP540U3C-A02UB Hard Drive Replacement: 5 단계, 이미지 1/2 Samsung NP540U3C-A02UB Hard Drive Replacement: 5 단계, 이미지 2/2
    • Using the plastic opening tool, push the hard drive connector clip upwards in order to release the cable.
  6. Samsung NP540U3C-A02UB Hard Drive Replacement: 6 단계, 이미지 1/2 Samsung NP540U3C-A02UB Hard Drive Replacement: 6 단계, 이미지 2/2
    • Remove the hard drive from the case.
결론
James Bourgeois
회원 가입일: 03/27/22
248 평판
안내서 1개 작성함
UMass Dartmouth, Team C-1, Gurgel Spring 2022 UMass Dartmouth, Team C-1, Gurgel Spring 2022 회원
UMASSD-GURGEL-S22SCG1
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 14
전체 시간: 398
