주요 콘텐츠로 건너뛰기
Samsung NP540U3C-A02UB RAM Replacement
필요한 것
  1. Samsung NP540U3C-A02UB RAM Replacement, Hard Drive: 1 단계, 이미지 1/1
    • Turn off the laptop before beginning disassembly and unplug it from the power cord.
    • Place the laptop flat with its bottom facing up.
  2. Samsung NP540U3C-A02UB RAM Replacement: 2 단계, 이미지 1/2 Samsung NP540U3C-A02UB RAM Replacement: 2 단계, 이미지 2/2
    • Remove one 4 mm Phillips #00 screw labeled "HDD Memory".
  3. Samsung NP540U3C-A02UB RAM Replacement: 3 단계, 이미지 1/3 Samsung NP540U3C-A02UB RAM Replacement: 3 단계, 이미지 2/3 Samsung NP540U3C-A02UB RAM Replacement: 3 단계, 이미지 3/3
    • Gently release the 3 clips holding the HDD cover with the plastic opening tool.
    • Remove the HDD cover from the device.
  4. Samsung NP540U3C-A02UB RAM Replacement: 4 단계, 이미지 1/2 Samsung NP540U3C-A02UB RAM Replacement: 4 단계, 이미지 2/2
    • Remove the four 6 mm Phillips #00 screws attaching the hard drive to the case.
  5. Samsung NP540U3C-A02UB RAM Replacement: 5 단계, 이미지 1/2 Samsung NP540U3C-A02UB RAM Replacement: 5 단계, 이미지 2/2
    • Using the plastic opening tool, push the hard drive connector clip upwards in order to release the cable.
  6. Samsung NP540U3C-A02UB RAM Replacement: 6 단계, 이미지 1/2 Samsung NP540U3C-A02UB RAM Replacement: 6 단계, 이미지 2/2
    • Remove the hard drive from the case.
  7. Samsung NP540U3C-A02UB RAM Replacement, RAM: 7 단계, 이미지 1/3 Samsung NP540U3C-A02UB RAM Replacement, RAM: 7 단계, 이미지 2/3 Samsung NP540U3C-A02UB RAM Replacement, RAM: 7 단계, 이미지 3/3
    • Remove the following screws holding the case together:
    • 6x 4mm Phillips #00 screws.
    • 3x 6mm Phillips #00 screws.
  8. Samsung NP540U3C-A02UB RAM Replacement: 8 단계, 이미지 1/2 Samsung NP540U3C-A02UB RAM Replacement: 8 단계, 이미지 2/2
    • Using the opening tool, remove the two rubber pads just above the hard drive cover.
  9. Samsung NP540U3C-A02UB RAM Replacement: 9 단계, 이미지 1/2 Samsung NP540U3C-A02UB RAM Replacement: 9 단계, 이미지 2/2
    • Remove the two 4mm Phillips #00 screws formerly concealed by the pads.
  10. Samsung NP540U3C-A02UB RAM Replacement: 10 단계, 이미지 1/1
    • Using the plastic opening tool, gently lift and remove the back cover.
    • There are clips along the edges of the back cover that hold it in place. Be careful not to break these.
  11. Samsung NP540U3C-A02UB RAM Replacement: 11 단계, 이미지 1/3 Samsung NP540U3C-A02UB RAM Replacement: 11 단계, 이미지 2/3 Samsung NP540U3C-A02UB RAM Replacement: 11 단계, 이미지 3/3
    • Lift up the white instruction guide with your hand to expose the RAM module underneath.
    • Using the plastic opening tool or your hand, peel off the yellow tape.
    • Using the plastic opening tool or your hand, gently remove the black cover that lays on top of the RAM.
  12. Samsung NP540U3C-A02UB RAM Replacement: 12 단계, 이미지 1/1
    • Additional RAM can be added or removed on top of the 4 GB RAM that comes with the laptop.
    • The new RAM chip slides on top in-between the brackets.
    • The 4 GB RAM that initially comes with the laptop can not be removed.
결론
Colby Bolger
회원 가입일: 03/28/22
277 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team C-1, Gurgel Spring 2022 UMass Dartmouth, Team C-1, Gurgel Spring 2022 회원
UMASSD-GURGEL-S22SCG1
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 206
