주요 콘텐츠로 건너뛰기
Samsung NP700Z5AH Battery Replacement
필요한 것
  1. Samsung NP700Z5AH Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Remove the ten 6.6mm Philips#00 screws securing the lower case to the upper case.
  2. Samsung NP700Z5AH Battery Replacement: 2 단계, 이미지 1/3 Samsung NP700Z5AH Battery Replacement: 2 단계, 이미지 2/3 Samsung NP700Z5AH Battery Replacement: 2 단계, 이미지 3/3
    • Using your fingers, pinch the edge of the SD card and pull to remove it.
  3. Samsung NP700Z5AH Battery Replacement: 3 단계, 이미지 1/2 Samsung NP700Z5AH Battery Replacement: 3 단계, 이미지 2/2
    • Wedge your fingers in between the upper case and the lower case
    • Gently pull the lower case away from the upper case to remove it
  4. Samsung NP700Z5AH Battery Replacement: 4 단계, 이미지 1/2 Samsung NP700Z5AH Battery Replacement: 4 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Using tweezers or your fingertips, carefully pull on the battery connector to disconnect it from the motherboard.
    • Be sure to pull straight backwards, or you risk damaging the wires.
  5. Samsung NP700Z5AH Battery Replacement: 5 단계, 이미지 1/1
    • Remove the two 4.4mm Phillips#00 screws from the battery case.
  6. Samsung NP700Z5AH Battery Replacement: 6 단계, 이미지 1/2 Samsung NP700Z5AH Battery Replacement: 6 단계, 이미지 2/2
    • Place your fingers on the corner sections of the battery.
    • Lift to remove the battery.
    • If you choose to use tools to remove the battery be careful not to damage it. A damaged lithium-ion battery may leak dangerous chemicals and/or catch fire. Use only plastic pry tools.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Erik
회원 가입일: 09/27/17
871 평판
안내서 6개 작성하였습니다
댓글 한 개
ifixit@distinctlydifferent.co.uk
Jacqueline - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 28
전체 시간: 1,052
