주요 콘텐츠로 건너뛰기
Samsung NP700Z5AH Optical Drive Replacement
필요한 것
  1. Samsung NP700Z5AH Optical Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Remove the ten 6.6mm Philips#00 screws securing the lower case to the upper case.
  2. Samsung NP700Z5AH Optical Drive Replacement: 2 단계, 이미지 1/3 Samsung NP700Z5AH Optical Drive Replacement: 2 단계, 이미지 2/3 Samsung NP700Z5AH Optical Drive Replacement: 2 단계, 이미지 3/3
    • Using your fingers, pinch the edge of the SD card and pull to remove it.
  3. Samsung NP700Z5AH Optical Drive Replacement: 3 단계, 이미지 1/2 Samsung NP700Z5AH Optical Drive Replacement: 3 단계, 이미지 2/2
    • Wedge your fingers in between the upper case and the lower case
    • Gently pull the lower case away from the upper case to remove it
  4. Samsung NP700Z5AH Optical Drive Replacement: 4 단계, 이미지 1/2 Samsung NP700Z5AH Optical Drive Replacement: 4 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Using tweezers or your fingertips, carefully pull on the battery connector to disconnect it from the motherboard.
    • Be sure to pull straight backwards, or you risk damaging the wires.
  5. Samsung NP700Z5AH Optical Drive Replacement: 5 단계, 이미지 1/1
    • Remove the two 4.4mm Phillips#00 screws from the battery case.
  6. Samsung NP700Z5AH Optical Drive Replacement: 6 단계, 이미지 1/2 Samsung NP700Z5AH Optical Drive Replacement: 6 단계, 이미지 2/2
    • Place your fingers on the corner sections of the battery.
    • Lift to remove the battery.
    • If you choose to use tools to remove the battery be careful not to damage it. A damaged lithium-ion battery may leak dangerous chemicals and/or catch fire. Use only plastic pry tools.
  7. Samsung NP700Z5AH Optical Drive Replacement, Optical Drive: 7 단계, 이미지 1/2 Samsung NP700Z5AH Optical Drive Replacement, Optical Drive: 7 단계, 이미지 2/2
    • Using your fingers, grasp the ribbon cable connected to the optical drive and pull it straight out to disconnect it.
    • To reinstall the cable, hold it near the end and push it straight into the connector, being careful not to kink the cable.
  8. Samsung NP700Z5AH Optical Drive Replacement: 8 단계, 이미지 1/2 Samsung NP700Z5AH Optical Drive Replacement: 8 단계, 이미지 2/2
    • Using the Phillips#00 remove the three 3.5mm screws that secure the speaker to the bottom case.
  9. Samsung NP700Z5AH Optical Drive Replacement: 9 단계, 이미지 1/2 Samsung NP700Z5AH Optical Drive Replacement: 9 단계, 이미지 2/2
    • With your fingers, grasp the edges of the speaker and slide it up and away from the fan to lift it out of the case.
  10. Samsung NP700Z5AH Optical Drive Replacement: 10 단계, 이미지 1/3 Samsung NP700Z5AH Optical Drive Replacement: 10 단계, 이미지 2/3 Samsung NP700Z5AH Optical Drive Replacement: 10 단계, 이미지 3/3
    • With the Phillips#00, remove the following screws holding the optical drive to the metal brackets.
    • Six 2.4mm screws
    • One 3.4mm screw
    • Using your fingers, grasp the metal brackets and remove them.
  11. Samsung NP700Z5AH Optical Drive Replacement: 11 단계, 이미지 1/2 Samsung NP700Z5AH Optical Drive Replacement: 11 단계, 이미지 2/2
    • Place your fingers on either side of the optical drive and slide it away from the fan to remove it.
결론
Erik
회원 가입일: 09/27/17
871 평판
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 13
전체 시간: 476
