주요 콘텐츠로 건너뛰기
Samsung NP900X4B RAM Replacement
필요한 것
  1. Samsung NP900X4B RAM Replacement, RAM: 1 단계, 이미지 1/1
    • This guide should be attempted after the removal of the back panel is completed.
    • The Battery Removal guide demonstrates how to do this. The link to this guide is posed here. Samsung NP900X4B Battery Replacement
  2. Samsung NP900X4B RAM Replacement: 2 단계, 이미지 1/1
    • Locate the two sticks or DDR3 RAM. They can be found in the upper right-hand corner.
  3. Samsung NP900X4B RAM Replacement: 3 단계, 이미지 1/3 Samsung NP900X4B RAM Replacement: 3 단계, 이미지 2/3 Samsung NP900X4B RAM Replacement: 3 단계, 이미지 3/3
    • Use a plastic opening tool to nudge one clamp holding one stick of RAM outward. If done correctly the clamp should move away from the stick of RAM. Do this with the clamp on the opposite side of the same stick or RAM. The stick of RAM will pop up when both clamps are released
  4. Samsung NP900X4B RAM Replacement: 4 단계, 이미지 1/1
    • Repeat step 3 with the second stick of RAM. Again, when this is done correctly the RAM should pop up at an angle away from the laptop.
  5. Samsung NP900X4B RAM Replacement: 5 단계, 이미지 1/1
    • Perform the previous steps in the reverse order to install two new sticks of RAM into the DDR3 slots. Make sure that the clamps click back in place. Failure to do so could result in non responsive sticks of RAM. If this is an issue, not to worry. Try taking the clamps off and reinstering the RAM.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Bryton Lawrence
회원 가입일: 10/17/18
327 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S4-G6, Valliere Fall 2018 UMass Dartmouth, Team S4-G6, Valliere Fall 2018 회원
UMASSD-VALLIERE-F18S4G6
5 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 10
전체 시간: 259
