주요 콘텐츠로 건너뛰기
Samsung NT300E5X-AD5S Hard Drive Replacement
필요한 것
  1. Samsung NT300E5X-AD5S Hard Drive Replacement, Hard Disk Drive (HDD): 1 단계, 이미지 1/3 Samsung NT300E5X-AD5S Hard Drive Replacement, Hard Disk Drive (HDD): 1 단계, 이미지 2/3 Samsung NT300E5X-AD5S Hard Drive Replacement, Hard Disk Drive (HDD): 1 단계, 이미지 3/3
    • Place the laptop with the backside facing up.
    • Remove the battery from the device by pushing out the slide locks to either end.
    • When reassembling the battery, you only need to push it back into its position.
  2. Samsung NT300E5X-AD5S Hard Drive Replacement: 2 단계, 이미지 1/3 Samsung NT300E5X-AD5S Hard Drive Replacement: 2 단계, 이미지 2/3 Samsung NT300E5X-AD5S Hard Drive Replacement: 2 단계, 이미지 3/3
    • Using the Phillips #00 screwdriver, loosen the 4 mm screw.
    • Remove the ODD/HDD/Memory panel by pushing it towards you.
  3. Samsung NT300E5X-AD5S Hard Drive Replacement: 3 단계, 이미지 1/3 Samsung NT300E5X-AD5S Hard Drive Replacement: 3 단계, 이미지 2/3 Samsung NT300E5X-AD5S Hard Drive Replacement: 3 단계, 이미지 3/3
    • Using the Phillips #00 screwdriver, remove the four 4 mm screws.
    • Carefully lift the mounting bracket out of the laptop.
  4. Samsung NT300E5X-AD5S Hard Drive Replacement: 4 단계, 이미지 1/2 Samsung NT300E5X-AD5S Hard Drive Replacement: 4 단계, 이미지 2/2
    • Hold the base of the connector under the hard drive disk (HDD).
    • Gently pull out the connector and separate the HDD from the device.
  5. Samsung NT300E5X-AD5S Hard Drive Replacement: 5 단계, 이미지 1/3 Samsung NT300E5X-AD5S Hard Drive Replacement: 5 단계, 이미지 2/3 Samsung NT300E5X-AD5S Hard Drive Replacement: 5 단계, 이미지 3/3
    • Using the Phillips #00 screwdriver, remove the four 4 mm screws from the mounting bracket.
    • Take off the HDD from the mounting bracket.
  6. Samsung NT300E5X-AD5S Hard Drive Replacement: 6 단계, 이미지 1/2 Samsung NT300E5X-AD5S Hard Drive Replacement: 6 단계, 이미지 2/2
    • Put the new HDD or solid state drive (SSD) onto the mounting bracket and secure the new drive using the Phillips #00 screwdriver to replace the four 4 mm screws.
결론
To reassemble your device, follow these instructions in reverse order. Turn on the laptop, and enter the BIOS setup by pressing the F2 button on the keyboard during the initial booting screen. Check the new drive at the section called "SATA Port 1".
다른 한 분이 해당 안내서를 완성하였습니다.
Yeonjong Choi
회원 가입일: 05/11/20
160 평판
안내서 1개 작성함
York University, Team S1-G7, O'Regan Summer 2020 York University, Team S1-G7, O'Regan Summer 2020 회원
YORK-O'REGAN-SU20S1G7
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 27
전체 시간: 854
