소개
Use this guide to replace an old and faulty hard disk drive in your Samsung NT300E5X-AD5S.
Hard disk drives get filled with unnecessary data or reached at its maximum capacity as a result of long-term read/write processes or external causes like heat. Such issues might cause software interrupts and could drastically drop the performance of the device. In the case of Samsung NT300E5X-AD5S, the default operating system (Windows 7) would notify you with an error message when there is an issue with the HDD. If then, replacing an old HDD to a new one or SSD could solve those problems.
Before taking down the device, make sure to remove the battery by following Step 1.
This guide demonstrates disassembly of the components, replacement of the HDD, and verification method for the new HDD (or SSD) installation.
필요한 것
Place the laptop with the backside facing up.
Remove the battery from the device by pushing out the slide locks to either end.
To reassemble your device, follow these instructions in reverse order. Turn on the laptop, and enter the BIOS setup by pressing the F2 button on the keyboard during the initial booting screen. Check the new drive at the section called "SATA Port 1".
다른 한 분이 해당 안내서를 완성하였습니다.
