주요 콘텐츠로 건너뛰기
Samsung NX1 Back Cover Replacement
필요한 것
  1. Samsung NX1 Back Cover Replacement, Viewfinder Focus Dial: 1 단계, 이미지 1/2 Samsung NX1 Back Cover Replacement, Viewfinder Focus Dial: 1 단계, 이미지 2/2
    • Push the rubber viewfinder grip upward.
  2. Samsung NX1 Back Cover Replacement: 2 단계, 이미지 1/2 Samsung NX1 Back Cover Replacement: 2 단계, 이미지 2/2
    • Use the Phillips #00 screwdriver to remove one 6.4 mm screw in the center of the dial.
    • Remove the dial by lifting upward with your fingers.
  3. Samsung NX1 Back Cover Replacement, Back Cover: 3 단계, 이미지 1/3 Samsung NX1 Back Cover Replacement, Back Cover: 3 단계, 이미지 2/3 Samsung NX1 Back Cover Replacement, Back Cover: 3 단계, 이미지 3/3
    • Use the Phillips #00 screwdriver to remove the four 5.5 mm screws surrounding the viewfinder.
    • Use your fingers to lift the plastic viewfinder cover upward.
  4. Samsung NX1 Back Cover Replacement: 4 단계, 이미지 1/2 Samsung NX1 Back Cover Replacement: 4 단계, 이미지 2/2
    • Use the Phillips #00 screwdriver to remove the two 5.5 mm screws from the right side of the camera above the SD card port.
  5. Samsung NX1 Back Cover Replacement: 5 단계, 이미지 1/1
    • Use the Phillips #00 screwdriver to remove one 5.5 mm screw on the left, above the HDMI port.
  6. Samsung NX1 Back Cover Replacement: 6 단계, 이미지 1/1
    • Use the Phillips #00 screwdriver to remove the five 5.5 mm screws from the bottom, near the battery compartment.
    • Use the Phillips #00 screwdriver to remove one 3.8 mm screw from the bottom of the hand grip, below the battery compartmen.
  7. Samsung NX1 Back Cover Replacement: 7 단계, 이미지 1/3 Samsung NX1 Back Cover Replacement: 7 단계, 이미지 2/3 Samsung NX1 Back Cover Replacement: 7 단계, 이미지 3/3
    • Use a plastic opening tool to separate the back cover from the front cover.
    • Pry the back cover in this order: bottom, right side, left side.
  8. Samsung NX1 Back Cover Replacement: 8 단계, 이미지 1/2 Samsung NX1 Back Cover Replacement: 8 단계, 이미지 2/2
    • Use your fingers to pull the back cover away from the front cover.
    • Do not completely separate the back cover from the front cover as two cables hold these components together.
  9. Samsung NX1 Back Cover Replacement: 9 단계, 이미지 1/3 Samsung NX1 Back Cover Replacement: 9 단계, 이미지 2/3 Samsung NX1 Back Cover Replacement: 9 단계, 이미지 3/3
    • Use tweezers to pull the two ribbon cables horizontally out of their clips.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Hannah Patrick
회원 가입일: 02/24/16
891 평판
안내서 6개 작성하였습니다
USF Tampa, Team 1-4, Leahy Spring 2016 USF Tampa, Team 1-4, Leahy Spring 2016 회원
USFT-LEAHY-S16S1G4
3 회원들
안내서 6개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 14
전체 시간: 875
