주요 콘텐츠로 건너뛰기
Samsung NX1 LCD Touch Screen Replacement
필요한 것
  1. Samsung NX1 LCD Touch Screen Replacement, Viewfinder Focus Dial: 1 단계, 이미지 2개 중 1개 Samsung NX1 LCD Touch Screen Replacement, Viewfinder Focus Dial: 1 단계, 이미지 2개 중 2개
    • Push the rubber viewfinder grip upward.
  2. Samsung NX1 LCD Touch Screen Replacement: 2 단계, 이미지 2개 중 1개 Samsung NX1 LCD Touch Screen Replacement: 2 단계, 이미지 2개 중 2개
    • Use the Phillips #00 screwdriver to remove one 6.4 mm screw in the center of the dial.
    • Remove the dial by lifting upward with your fingers.
  3. Samsung NX1 LCD Touch Screen Replacement, Back Cover: 3 단계, 이미지 3개 중 1개 Samsung NX1 LCD Touch Screen Replacement, Back Cover: 3 단계, 이미지 3개 중 2개 Samsung NX1 LCD Touch Screen Replacement, Back Cover: 3 단계, 이미지 3개 중 3개
    • Use the Phillips #00 screwdriver to remove the four 5.5 mm screws surrounding the viewfinder.
    • Use your fingers to lift the plastic viewfinder cover upward.
  4. Samsung NX1 LCD Touch Screen Replacement: 4 단계, 이미지 2개 중 1개 Samsung NX1 LCD Touch Screen Replacement: 4 단계, 이미지 2개 중 2개
    • Use the Phillips #00 screwdriver to remove the two 5.5 mm screws from the right side of the camera above the SD card port.
  5. Samsung NX1 LCD Touch Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Use the Phillips #00 screwdriver to remove one 5.5 mm screw on the left, above the HDMI port.
  6. Samsung NX1 LCD Touch Screen Replacement: 6 단계, 이미지 1개 중 1개
    • Use the Phillips #00 screwdriver to remove the five 5.5 mm screws from the bottom, near the battery compartment.
    • Use the Phillips #00 screwdriver to remove one 3.8 mm screw from the bottom of the hand grip, below the battery compartmen.
  7. Samsung NX1 LCD Touch Screen Replacement: 7 단계, 이미지 3개 중 1개 Samsung NX1 LCD Touch Screen Replacement: 7 단계, 이미지 3개 중 2개 Samsung NX1 LCD Touch Screen Replacement: 7 단계, 이미지 3개 중 3개
    • Use a plastic opening tool to separate the back cover from the front cover.
    • Pry the back cover in this order: bottom, right side, left side.
  8. Samsung NX1 LCD Touch Screen Replacement: 8 단계, 이미지 2개 중 1개 Samsung NX1 LCD Touch Screen Replacement: 8 단계, 이미지 2개 중 2개
    • Use your fingers to pull the back cover away from the front cover.
    • Do not completely separate the back cover from the front cover as two cables hold these components together.
  9. Samsung NX1 LCD Touch Screen Replacement: 9 단계, 이미지 3개 중 1개 Samsung NX1 LCD Touch Screen Replacement: 9 단계, 이미지 3개 중 2개 Samsung NX1 LCD Touch Screen Replacement: 9 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use tweezers to pull the two ribbon cables horizontally out of their clips.
  10. Samsung NX1 LCD Touch Screen Replacement, LCD Touch Screen: 10 단계, 이미지 1개 중 1개
    • Use the Phillips #00 screwdriver to remove the seven screws (three silver 3.5 mm screws and four black 2.7 mm screws).
  11. Samsung NX1 LCD Touch Screen Replacement: 11 단계, 이미지 2개 중 1개 Samsung NX1 LCD Touch Screen Replacement: 11 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers to remove the glued rubber piece.
  12. Samsung NX1 LCD Touch Screen Replacement: 12 단계, 이미지 3개 중 1개 Samsung NX1 LCD Touch Screen Replacement: 12 단계, 이미지 3개 중 2개 Samsung NX1 LCD Touch Screen Replacement: 12 단계, 이미지 3개 중 3개
    • Use the Phillips #00 screwdriver to remove the four black 2.3 mm screws.
    • Use your fingers to separate the LCD screen from the folding mechanism.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Hannah Patrick
회원 가입일: 02/24/16
903 평판
안내서 6개를 작성함
USF Tampa, Team 1-4, Leahy Spring 2016 USF Tampa, Team 1-4, Leahy Spring 2016 회원
USFT-LEAHY-S16S1G4
3 회원들
안내서 6개를 작성함
5가이드 댓글
Where can one buy a new screen?
Lourens Coetzee - 답글
Where to get new screen?
Jonathan Wood - 답글
Thanks! This guide is missing some steps and details once you open it up, but it was enough for me to get the job done. Thank you.
Once inside be super careful with the ribbon cables. One slides out the side and the cable labeled “Main” pops off the top. At first I thought I broke the Main cable. You’ll need to unhood the main cable from the frame before you can detach the LCD… and the LCD is glued on airtight to the articulating frame.
I ordered a new replacement LCD on ebay from S. Korea. Good luck to anyone else who has to do this. I killed my screen after a couple heavy rain storms.
drew - 답글
One more question: where can I order a display for the NX1?
Henning Marx - 답글
DID anyone have to fix a broken folding mechanism?
Daniele. Pianciola - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 11
지난 30일: 37
전체 시간: 1,536
