주요 콘텐츠로 건너뛰기
Samsung NX1 Motherboard Replacement
필요한 것
  1. Samsung NX1 Motherboard  Replacement, Back Cover: 1 단계, 이미지 3개 중 1개 Samsung NX1 Motherboard  Replacement, Back Cover: 1 단계, 이미지 3개 중 2개 Samsung NX1 Motherboard  Replacement, Back Cover: 1 단계, 이미지 3개 중 3개
    • Use the Phillips #00 screwdriver to remove the four 5.5 mm screws surrounding the viewfinder.
    • Use your fingers to lift the plastic viewfinder cover upward.
  2. Samsung NX1 Motherboard  Replacement: 2 단계, 이미지 2개 중 1개 Samsung NX1 Motherboard  Replacement: 2 단계, 이미지 2개 중 2개
    • Use the Phillips #00 screwdriver to remove the two 5.5 mm screws from the right side of the camera above the SD card port.
  3. Samsung NX1 Motherboard  Replacement: 3 단계, 이미지 1개 중 1개
    • Use the Phillips #00 screwdriver to remove one 5.5 mm screw on the left, above the HDMI port.
  4. Samsung NX1 Motherboard  Replacement: 4 단계, 이미지 1개 중 1개
    • Use the Phillips #00 screwdriver to remove the five 5.5 mm screws from the bottom, near the battery compartment.
    • Use the Phillips #00 screwdriver to remove one 3.8 mm screw from the bottom of the hand grip, below the battery compartmen.
  5. Samsung NX1 Motherboard  Replacement: 5 단계, 이미지 3개 중 1개 Samsung NX1 Motherboard  Replacement: 5 단계, 이미지 3개 중 2개 Samsung NX1 Motherboard  Replacement: 5 단계, 이미지 3개 중 3개
    • Use a plastic opening tool to separate the back cover from the front cover.
    • Pry the back cover in this order: bottom, right side, left side.
  6. Samsung NX1 Motherboard  Replacement: 6 단계, 이미지 2개 중 1개 Samsung NX1 Motherboard  Replacement: 6 단계, 이미지 2개 중 2개
    • Use your fingers to pull the back cover away from the front cover.
    • Do not completely separate the back cover from the front cover as two cables hold these components together.
  7. Samsung NX1 Motherboard  Replacement: 7 단계, 이미지 3개 중 1개 Samsung NX1 Motherboard  Replacement: 7 단계, 이미지 3개 중 2개 Samsung NX1 Motherboard  Replacement: 7 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use tweezers to pull the two ribbon cables horizontally out of their clips.
  8. Samsung NX1 Motherboard  Replacement, Motherboard: 8 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use tweezers to pull the five ribbon cables horizontally out of their clips.
    • Use a spudger or your fingernail to flip up the four, small retaining flap, or zero insertion force (ZIF) connectors. Then, pull the ribbon cable out to disconnect it.
    • Remove the green tape using your fingernail. Then, use a spudger to pry the one antenna cable connector straight up from the board.
    • Use tweezers or a spudger to pry up each side of the flat-topped connector. Then, lift the one connector straight up from its socket.
    • Use tweezers or your fingers to pull the two double-bundled cables up and away from the connector in the same direction that the individual wires are running.
  9. Samsung NX1 Motherboard  Replacement: 9 단계, 이미지 1개 중 1개
    • Use the Phillips #00 screwdriver to remove the six silver 4.5 mm screws.
  10. Samsung NX1 Motherboard  Replacement: 10 단계, 이미지 2개 중 1개 Samsung NX1 Motherboard  Replacement: 10 단계, 이미지 2개 중 2개
    • Use a spudger to lift the motherboard up starting on the right side proceeding to the left side.
    • Use your fingers to lift the motherboard completely out of the camera.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Hannah Patrick
회원 가입일: 02/24/16
903 평판
안내서 6개를 작성함
USF Tampa, Team 1-4, Leahy Spring 2016 USF Tampa, Team 1-4, Leahy Spring 2016 회원
USFT-LEAHY-S16S1G4
3 회원들
안내서 6개를 작성함
4가이드 댓글
Hi this was very informative, bt do you know where i can find a replacemen mainboard ?...i've been looking but no luck
levirono36 - 답글
Hi all
Does anyone know where can I found the service manual for this camera? I really need it!!! I need to take off the upper buttons and the upper LCD screen!!!
Thanks in advance.
Sotirios Konstantinou
sotsma@gmail.com
SOTIRIOS KONSTANTINOU - 답글
Hi, thanks for the tutorial ! I would like to know where i can find a motherboard for samsung nx1 please ? I would like to buy it because my sd card broke the sd slot of my camera. Thanks for your help.
Steven - 답글
Hello, the mode switch does not function well. I want to buy a top cover complete with all the switches. Please tell me how to replace this cover. Thank.
https://clck.ru/PWTXQ
Mermelstein - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 32
전체 시간: 2,117
