주요 콘텐츠로 건너뛰기
Samsung NX1 Viewfinder Replacement
필요한 것
  1. Samsung NX1 Viewfinder Replacement, Viewfinder Focus Dial: 1 단계, 이미지 1/2 Samsung NX1 Viewfinder Replacement, Viewfinder Focus Dial: 1 단계, 이미지 2/2
    • Push the rubber viewfinder grip upward.
  2. Samsung NX1 Viewfinder Replacement: 2 단계, 이미지 1/2 Samsung NX1 Viewfinder Replacement: 2 단계, 이미지 2/2
    • Use the Phillips #00 screwdriver to remove one 6.4 mm screw in the center of the dial.
    • Remove the dial by lifting upward with your fingers.
  3. Samsung NX1 Viewfinder Replacement, Back Cover: 3 단계, 이미지 1/3 Samsung NX1 Viewfinder Replacement, Back Cover: 3 단계, 이미지 2/3 Samsung NX1 Viewfinder Replacement, Back Cover: 3 단계, 이미지 3/3
    • Use the Phillips #00 screwdriver to remove the four 5.5 mm screws surrounding the viewfinder.
    • Use your fingers to lift the plastic viewfinder cover upward.
  4. Samsung NX1 Viewfinder Replacement: 4 단계, 이미지 1/2 Samsung NX1 Viewfinder Replacement: 4 단계, 이미지 2/2
    • Use the Phillips #00 screwdriver to remove the two 5.5 mm screws from the right side of the camera above the SD card port.
  5. Samsung NX1 Viewfinder Replacement: 5 단계, 이미지 1/1
    • Use the Phillips #00 screwdriver to remove one 5.5 mm screw on the left, above the HDMI port.
  6. Samsung NX1 Viewfinder Replacement: 6 단계, 이미지 1/1
    • Use the Phillips #00 screwdriver to remove the five 5.5 mm screws from the bottom, near the battery compartment.
    • Use the Phillips #00 screwdriver to remove one 3.8 mm screw from the bottom of the hand grip, below the battery compartmen.
  7. Samsung NX1 Viewfinder Replacement: 7 단계, 이미지 1/3 Samsung NX1 Viewfinder Replacement: 7 단계, 이미지 2/3 Samsung NX1 Viewfinder Replacement: 7 단계, 이미지 3/3
    • Use a plastic opening tool to separate the back cover from the front cover.
    • Pry the back cover in this order: bottom, right side, left side.
  8. Samsung NX1 Viewfinder Replacement: 8 단계, 이미지 1/2 Samsung NX1 Viewfinder Replacement: 8 단계, 이미지 2/2
    • Use your fingers to pull the back cover away from the front cover.
    • Do not completely separate the back cover from the front cover as two cables hold these components together.
  9. Samsung NX1 Viewfinder Replacement: 9 단계, 이미지 1/3 Samsung NX1 Viewfinder Replacement: 9 단계, 이미지 2/3 Samsung NX1 Viewfinder Replacement: 9 단계, 이미지 3/3
    • Use tweezers to pull the two ribbon cables horizontally out of their clips.
  10. Samsung NX1 Viewfinder Replacement, LCD Touch Screen: 10 단계, 이미지 1/1
    • Use the Phillips #00 screwdriver to remove the seven screws (three silver 3.5 mm screws and four black 2.7 mm screws).
  11. Samsung NX1 Viewfinder Replacement: 11 단계, 이미지 1/2 Samsung NX1 Viewfinder Replacement: 11 단계, 이미지 2/2
    • Use tweezers to remove the glued rubber piece.
  12. Samsung NX1 Viewfinder Replacement: 12 단계, 이미지 1/3 Samsung NX1 Viewfinder Replacement: 12 단계, 이미지 2/3 Samsung NX1 Viewfinder Replacement: 12 단계, 이미지 3/3
    • Use the Phillips #00 screwdriver to remove the four black 2.3 mm screws.
    • Use your fingers to separate the LCD screen from the folding mechanism.
  13. Samsung NX1 Viewfinder Replacement, Motherboard: 13 단계, 이미지 1/1
    • Use tweezers to pull the five ribbon cables horizontally out of their clips.
    • Use a spudger or your fingernail to flip up the four, small retaining flap, or zero insertion force (ZIF) connectors. Then, pull the ribbon cable out to disconnect it.
    • Remove the green tape using your fingernail. Then, use a spudger to pry the one antenna cable connector straight up from the board.
    • Use tweezers or a spudger to pry up each side of the flat-topped connector. Then, lift the one connector straight up from its socket.
    • Use tweezers or your fingers to pull the two double-bundled cables up and away from the connector in the same direction that the individual wires are running.
  14. Samsung NX1 Viewfinder Replacement: 14 단계, 이미지 1/1
    • Use the Phillips #00 screwdriver to remove the six silver 4.5 mm screws.
  15. Samsung NX1 Viewfinder Replacement: 15 단계, 이미지 1/2 Samsung NX1 Viewfinder Replacement: 15 단계, 이미지 2/2
    • Use a spudger to lift the motherboard up starting on the right side proceeding to the left side.
    • Use your fingers to lift the motherboard completely out of the camera.
  16. Samsung NX1 Viewfinder Replacement, Viewfinder: 16 단계, 이미지 1/1
    • Use tweezers to lift the black tab on the ZIF connector.
    • Use tweezers to pull the large orange ribbon cable out of the connector to get a clearer view of the screws lying beneath it.
  17. Samsung NX1 Viewfinder Replacement: 17 단계, 이미지 1/1
    • Use the Phillips #00 screwdriver to remove the three black 3.8 mm screws below the viewfinder.
  18. Samsung NX1 Viewfinder Replacement: 18 단계, 이미지 1/2 Samsung NX1 Viewfinder Replacement: 18 단계, 이미지 2/2
    • Use a spudger to gently push the viewfinder cube, starting at the top of the cube and pushing it toward the bottom of the camera.
    • Use your fingers to lift the viewfinder cube out of the camera.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Hannah Patrick
회원 가입일: 02/24/16
891 평판
안내서 6개 작성하였습니다
USF Tampa, Team 1-4, Leahy Spring 2016 USF Tampa, Team 1-4, Leahy Spring 2016 회원
USFT-LEAHY-S16S1G4
3 회원들
안내서 6개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 15
전체 시간: 942
