주요 콘텐츠로 건너뛰기
Samsung NX1000 Front Lens Cover Replacement
필요한 것
  1. Samsung NX1000 Front Lens Cover Replacement, Front Lens Cover: 1 단계, 이미지 1/2 Samsung NX1000 Front Lens Cover Replacement, Front Lens Cover: 1 단계, 이미지 2/2
    • Unscrew the four 5.5 mm #000 Philips screws that are on the metal ring with a Philips #000 screwdriver.
  2. Samsung NX1000 Front Lens Cover Replacement: 2 단계, 이미지 1/2 Samsung NX1000 Front Lens Cover Replacement: 2 단계, 이미지 2/2
    • Remove the metal ring using the plastic opening tool.
  3. Samsung NX1000 Front Lens Cover Replacement: 3 단계, 이미지 1/2 Samsung NX1000 Front Lens Cover Replacement: 3 단계, 이미지 2/2
    • Remove the black plastic ring using the plastic opening tool.
  4. Samsung NX1000 Front Lens Cover Replacement: 4 단계, 이미지 1/2 Samsung NX1000 Front Lens Cover Replacement: 4 단계, 이미지 2/2
    • Remove the thin metal ring.
  5. Samsung NX1000 Front Lens Cover Replacement: 5 단계, 이미지 1/1
    • Remove the three 4.5 mm Phillips #000 head screws located inside the cover with a Phillips #000 screwdriver.
  6. Samsung NX1000 Front Lens Cover Replacement: 6 단계, 이미지 1/2 Samsung NX1000 Front Lens Cover Replacement: 6 단계, 이미지 2/2
    • There are a few loose metal parts and springs. Be careful not to shake the device.
    • Remove the white plastic ring.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Yesenia
회원 가입일: 01/22/15
717 평판
안내서 6개 작성하였습니다
Cal Poly, Team 20-13, Maness Winter 2015 Cal Poly, Team 20-13, Maness Winter 2015 회원
CPSU-MANESS-W15S20G13
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 14
전체 시간: 2,024
