소개
If you need to replacement your front lens, here is the guide to do so. Be sure to turn off your camera and take out the battery before you being your replacement.
필요한 것
Unscrew the four 5.5 mm #000 Philips screws that are on the metal ring with a Philips #000 screwdriver.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
