소개
This guide will show you how to replace the motherboard in the camera. Be sure to turn off the camera and remove the battery before you being your replacement.
필요한 것
Locate the bottom panel of the camera.
Unscrew the four 4.5mm Philips #000 (perpendicular cross) screws with the Philips #000 screwdriver.
Remove the black rubber tape with the plastic opening tool and slowly peel it off.
다른 한 분이 해당 안내서를 완성하였습니다.
