주요 콘텐츠로 건너뛰기
Samsung NX2000 Battery Replacement
  1. Samsung NX2000 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Place the camera upside down with the lens facing you.
  2. Samsung NX2000 Battery Replacement: 2 단계, 이미지 1/1
    • Locate the sliding latch on the right side of the camera and slide the latch to the left side to open up the battery compartment.
  3. Samsung NX2000 Battery Replacement: 3 단계, 이미지 1/1
    • Locate the blue release lever holding the battery down. Slide the blue lever to the right to release the battery itself.
  4. Samsung NX2000 Battery Replacement: 4 단계, 이미지 1/1
    • The battery will now slide up about an inch allowing the battery to be pulled out of the camera.
  5. Samsung NX2000 Battery Replacement: 5 단계, 이미지 1/1
    • Insert the new battery with the arrow on the battery pointing into the camera. The red square indicates the location of the arrow.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
David Edbom
회원 가입일: 02/09/16
119 평판
안내서 1개 작성함
USF Tampa, Team 7-4, Cheng Spring 2016 USF Tampa, Team 7-4, Cheng Spring 2016 회원
USFT-CHENG-S16S7G4
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 6
전체 시간: 833
