주요 콘텐츠로 건너뛰기
Samsung NX2000 Lens Assembly Replacement
필요한 것
  1. Samsung NX2000 Lens Assembly Replacement, Lens Assembly: 1 단계, 이미지 1/2 Samsung NX2000 Lens Assembly Replacement, Lens Assembly: 1 단계, 이미지 2/2
    • Begin by pressing the lens lock button to the right of the lens.
    • Release the button and turn the lens in a clockwise motion until you have removed the lens.
  2. Samsung NX2000 Lens Assembly Replacement: 2 단계, 이미지 1/3 Samsung NX2000 Lens Assembly Replacement: 2 단계, 이미지 2/3 Samsung NX2000 Lens Assembly Replacement: 2 단계, 이미지 3/3
    • Make sure your camera is turned off and flip your device upside down.
    • Slide the battery switch to the left and open the battery compartment.
    • Push the blue button up inside the battery compartment and remove the battery.
  3. Samsung NX2000 Lens Assembly Replacement: 3 단계, 이미지 1/3 Samsung NX2000 Lens Assembly Replacement: 3 단계, 이미지 2/3 Samsung NX2000 Lens Assembly Replacement: 3 단계, 이미지 3/3
    • Remove the four 4mm screws highlighted here with the Y0 screwdriver.
    • Using a tweezer, gently remove the outer silver lens lining.
    • Underneath will lie a black ring, which needs to removed using the same tweezer.
  4. Samsung NX2000 Lens Assembly Replacement: 4 단계, 이미지 1/3 Samsung NX2000 Lens Assembly Replacement: 4 단계, 이미지 2/3 Samsung NX2000 Lens Assembly Replacement: 4 단계, 이미지 3/3
    • Remove the final silver ring from the lens assembly using a tweezer.
    • Using a slanted tweezer, remove the highlighted pyramid screw from the compartment shown.
    • Remove the spring from the same compartment using the same tool.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Katarina Raic
회원 가입일: 02/09/16
288 평판
안내서 2개 작성하였습니다
USF Tampa, Team 7-4, Cheng Spring 2016 USF Tampa, Team 7-4, Cheng Spring 2016 회원
USFT-CHENG-S16S7G4
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 16
전체 시간: 876
