주요 콘텐츠로 건너뛰기
Samsung NX2000 Motherboard Replacement
필요한 것
  1. Samsung NX2000 Motherboard Replacement, Motherboard: 1 단계, 이미지 1/3 Samsung NX2000 Motherboard Replacement, Motherboard: 1 단계, 이미지 2/3 Samsung NX2000 Motherboard Replacement, Motherboard: 1 단계, 이미지 3/3
    • Remove the 4mm Y0 screws found on the sides and bottom of the camera.
  2. Samsung NX2000 Motherboard Replacement: 2 단계, 이미지 1/3 Samsung NX2000 Motherboard Replacement: 2 단계, 이미지 2/3 Samsung NX2000 Motherboard Replacement: 2 단계, 이미지 3/3
    • Use a plastic opening tool to pry the back cover (with LCD screen) away from the front of the camera.
    • Use a plastic opening tool to disconnect the LCD ribbon cable holding the two pieces of the camera together.
  3. Samsung NX2000 Motherboard Replacement: 3 단계, 이미지 1/1
    • Move towards the main frame of the camera and locate the three 1mm Y0 screws holding down the motherboard.
  4. Samsung NX2000 Motherboard Replacement: 4 단계, 이미지 1/2 Samsung NX2000 Motherboard Replacement: 4 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Lift the duct tape covering the ribbon cable connectors.
    • Use a plastic opening tool to lift the black tab on top of the ZIF connectors.
    • Pull all five ribbon cables out with tweezers.
  5. Samsung NX2000 Motherboard Replacement: 5 단계, 이미지 1/3 Samsung NX2000 Motherboard Replacement: 5 단계, 이미지 2/3 Samsung NX2000 Motherboard Replacement: 5 단계, 이미지 3/3
    • Take the time to make sure everything is detached and lift the motherboard slowly using your fingers.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Delmis Gomez
회원 가입일: 02/09/16
125 평판
안내서 1개 작성함
USF Tampa, Team 7-4, Cheng Spring 2016 USF Tampa, Team 7-4, Cheng Spring 2016 회원
USFT-CHENG-S16S7G4
4 회원들
안내서 10개 작성하였습니다
댓글 4개
The step for removing the metal hot shoe lit and removing 2 small screws is missing.
This is also required in order to be able to remove the back cover.
Rinaldo Eversdijk - 답글
The step removing the metal hot shoe lit and removing 2 small screws underneath is missing.
This is required in order to be able to remove the back cover.
The camera is simply dead from one day to the next it stopped working, what could it be?
my_legacy_lethal_infected - 답글
Aqui a mesma coisa, do nada, quando liga a câmera o LED Verde fica parado e em seguida pisca alternadamente, ESTÁ NOVISSIMA, nunca sofreu quedas ou qualquer outro tipo de avaria
Gabriel Fernandes Guimaraes -
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 4
30일 전: 17
전체 시간: 1,400
