주요 콘텐츠로 건너뛰기
Samsung NX30 Screen Replacement
필요한 것
  1. Samsung NX30 Screen Replacement, Battery: 1 단계, 이미지 1/1
    • Flip the camera over so that the bottom of the camera is up.
    • Push the battery switch towards the back of the camera.
  2. Samsung NX30 Screen Replacement: 2 단계, 이미지 1/2 Samsung NX30 Screen Replacement: 2 단계, 이미지 2/2
    • Locate the blue switch above the battery pack.
    • Slide the blue switch into the camera in the direction of the arrow on the switch. When the switch has been pushed in the battery will spring up.
  3. Samsung NX30 Screen Replacement: 3 단계, 이미지 1/1
    • Pull the battery out.
  4. Samsung NX30 Screen Replacement, Screen: 4 단계, 이미지 1/3 Samsung NX30 Screen Replacement, Screen: 4 단계, 이미지 2/3 Samsung NX30 Screen Replacement, Screen: 4 단계, 이미지 3/3
    • Unscrew the nine 4mm Phillips head screws surrounding the body of the camera. They are located on the bottom of the camera and both sides of the camera.
  5. Samsung NX30 Screen Replacement: 5 단계, 이미지 1/3 Samsung NX30 Screen Replacement: 5 단계, 이미지 2/3 Samsung NX30 Screen Replacement: 5 단계, 이미지 3/3
    • Pull the viewer out from the camera and then up.
    • Unscrew the two black 4mm Phillips head screws under it.
  6. Samsung NX30 Screen Replacement: 6 단계, 이미지 1/2 Samsung NX30 Screen Replacement: 6 단계, 이미지 2/2
    • Once the screws are all removed, place the camera face down, with the screen facing up.
    • Pry open the body using the plastic opening tool.
    • Gently open the body.
  7. Samsung NX30 Screen Replacement: 7 단계, 이미지 1/2 Samsung NX30 Screen Replacement: 7 단계, 이미지 2/2
    • Then use the plastic opening tool to dislodge the Ribbon Cable, located near the top of the camera, from the Circuit Board.
    • The Ribbon Cable will be disconnected from the Circuit Board when you are done.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Julia Kilcup
회원 가입일: 02/03/16
399 평판
안내서 3개 작성하였습니다
UW Tacoma, Team 1-4, Rose Winter 2016 UW Tacoma, Team 1-4, Rose Winter 2016 회원
UWT-ROSE-W16S1G4
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 9
전체 시간: 1,867
