주요 콘텐츠로 건너뛰기
Samsung NX300 and NX300M Back Panel Assembly Replacement
필요한 것
  1. Samsung NX300 and NX300M Back Panel Assembly Replacement, Unscrew the Back Panel: 1 단계, 이미지 1/2 Samsung NX300 and NX300M Back Panel Assembly Replacement, Unscrew the Back Panel: 1 단계, 이미지 2/2
    • Using a Phillips #00 precision screwdriver, remove the seven 4mm screws (5 on the bottom of the device and 1 on each of the two sides) holding the back panel to the camera.
    • On the NX300M model, there is an additional screw under the text AMOLED behind display which should be removed before detaching the back panel of the camera.
  2. Samsung NX300 and NX300M Back Panel Assembly Replacement, Remove the Input Port Screw: 2 단계, 이미지 1/1
    • Using a Phillips #00 precision screwdriver, remove the last 4 mm screw located inside the input ports' compartment.
  3. Samsung NX300 and NX300M Back Panel Assembly Replacement, Open the Camera Casing: 3 단계, 이미지 1/3 Samsung NX300 and NX300M Back Panel Assembly Replacement, Open the Camera Casing: 3 단계, 이미지 2/3 Samsung NX300 and NX300M Back Panel Assembly Replacement, Open the Camera Casing: 3 단계, 이미지 3/3
    • Place a plastic opening tool into the gap between the back panel and camera body, from both the top and the bottom of camera. Carefully pry open the camera and separate the back panel.
  4. Samsung NX300 and NX300M Back Panel Assembly Replacement, Remove the Back Panel: 4 단계, 이미지 1/3 Samsung NX300 and NX300M Back Panel Assembly Replacement, Remove the Back Panel: 4 단계, 이미지 2/3 Samsung NX300 and NX300M Back Panel Assembly Replacement, Remove the Back Panel: 4 단계, 이미지 3/3
    • Using tweezers or your fingers, pull the display's black ribbon from the motherboard. This frees the back panel altogether.
    • To safely remove ribbons, you would need to first unlock the holding mechanism by lifting up the black strip atop the ribbon adapter.
결론
다른 11명이 해당 안내서를 완성하였습니다.
Andres Perez
회원 가입일: 01/21/15
951 평판
안내서 5개 작성하였습니다
USF Tampa, Team 9-6, Blackwell Winter 2015 USF Tampa, Team 9-6, Blackwell Winter 2015 회원
USFT-BLACKWELL-W15S9G6
4 회원들
안내서 10개 작성하였습니다
댓글 2개
I had to replace the back panel when my amoled screen started going bad. Thanks for a great tutorial!
Amanda Aiken - 답글
Hello, can anybody tell me if the display of SAMSUNG NX 300 M match to a SAMSUNG NX 300 ? I need to replace the display of NX 300 and i dont find any pieces but i found an NX 300 M
Norbert - Ciprian Patras - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 24
전체 시간: 4,990
