주요 콘텐츠로 건너뛰기
Samsung NX500 SD card Replacement
  1. Samsung NX500 SD card Replacement, SD card: 1 단계, 이미지 1/2 Samsung NX500 SD card Replacement, SD card: 1 단계, 이미지 2/2
    • Locate the bottom of the camera.
    • Slide the opening latch down to expose the battery and SD card location.
  2. Samsung NX500 SD card Replacement: 2 단계, 이미지 1/1
    • The SD card location is above where the battery is.
    • Push down on the SD card and it will 'pop' open.
    • Careful not to push down too hard as it requires very little force.
결론
Eli Carcalete
회원 가입일: 09/15/16
575 평판
안내서 4개 작성하였습니다
USF Tampa, Team 18-5, Blackwell Fall 2016 USF Tampa, Team 18-5, Blackwell Fall 2016 회원
USFT-BLACKWELL-F16S18G5
3 회원들
안내서 12개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 265
