주요 콘텐츠로 건너뛰기
Samsung NX500 Screen Assembly Replacement
필요한 것
  1. Samsung NX500 Screen Assembly Replacement, Battery: 1 단계, 이미지 1/2 Samsung NX500 Screen Assembly Replacement, Battery: 1 단계, 이미지 2/2
    • Pull the switch on the bottom of the camera back with your thumb.
  2. Samsung NX500 Screen Assembly Replacement: 2 단계, 이미지 1/2 Samsung NX500 Screen Assembly Replacement: 2 단계, 이미지 2/2
    • Push second switch(blue) forward with your thumb.
  3. Samsung NX500 Screen Assembly Replacement: 3 단계, 이미지 1/1
    • Pull out battery.
  4. Samsung NX500 Screen Assembly Replacement, Screen Side Encasement: 4 단계, 이미지 1/3 Samsung NX500 Screen Assembly Replacement, Screen Side Encasement: 4 단계, 이미지 2/3 Samsung NX500 Screen Assembly Replacement, Screen Side Encasement: 4 단계, 이미지 3/3
    • Open the screen exposing the hinge cover and place the plastic opening tool inside.
    • Pry the hinge cover up by moving the plastic opening tool in a downward motion.
    • Remove the black 4mm Phillips #000 screw that is revealed once the hinge cover is removed.
  5. Samsung NX500 Screen Assembly Replacement: 5 단계, 이미지 1/3 Samsung NX500 Screen Assembly Replacement: 5 단계, 이미지 2/3 Samsung NX500 Screen Assembly Replacement: 5 단계, 이미지 3/3
    • Unscrew the two 4 mm Phillips #000 screws on the right hand side of the camera using the screwdriver.
    • Unscrew five more 4 mm Phillips #000 screws that are located at the bottom of the camera with the screwdriver.
    • In the second step, do not the remove the two 4 mm Phillips #000 screen on the screen.
    • Remove the last exterior 4 mm Phillips #000 screws on the left hand side of the camera with the scredriver.
  6. Samsung NX500 Screen Assembly Replacement: 6 단계, 이미지 1/2 Samsung NX500 Screen Assembly Replacement: 6 단계, 이미지 2/2
    • Use the plastic opening tool in a downward motion around each side of the camera to pry the casing open.
    • The casing should be removed easily; you shouldn't have to use much force.
  7. Samsung NX500 Screen Assembly Replacement: 7 단계, 이미지 1/2 Samsung NX500 Screen Assembly Replacement: 7 단계, 이미지 2/2
    • Locate the black ribbon at the bottom left of the camera's interior.
    • Place the plastic opening tool under the black ribbon connector.
    • Remove the cable by moving your plastic opening tool in a downward motion.
    • There is zero to little force needed to remove this ribbon.
  8. Samsung NX500 Screen Assembly Replacement, Screen Assembly: 8 단계, 이미지 1/2 Samsung NX500 Screen Assembly Replacement, Screen Assembly: 8 단계, 이미지 2/2
    • Locate where the white ribbon cable connects to the black LCD cable.
    • Using both hands, separate the cables by pulling them away from each other.
  9. Samsung NX500 Screen Assembly Replacement: 9 단계, 이미지 1/1
    • Remove the four black 2-mm Phillips type 000 using the screwdriver.
    • Remark : Since these four screwdrivers are easilly loosen during normal handling, be sure that screw them very fasten or screw with a bond suck like Loctite when reassembling.
  10. Samsung NX500 Screen Assembly Replacement: 10 단계, 이미지 1/3 Samsung NX500 Screen Assembly Replacement: 10 단계, 이미지 2/3 Samsung NX500 Screen Assembly Replacement: 10 단계, 이미지 3/3
    • Carefully grab the LCD cable and begin to guide it through the hole it comes enters from.
    • Maneuver the connector through the exit site.
    • Carefully pull the cable through from the exterior of the screen encasement.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Eli Carcalete
회원 가입일: 09/15/16
575 평판
안내서 4개 작성하였습니다
USF Tampa, Team 18-5, Blackwell Fall 2016 USF Tampa, Team 18-5, Blackwell Fall 2016 회원
USFT-BLACKWELL-F16S18G5
3 회원들
안내서 12개 작성하였습니다
4 댓글
Hello Eli! I was wondering if you buy a new screen for replace, is this comes with the FPC cable? I mean, the black one. Thanks a lot!
Sophie Kovalevsky - 답글
Hi, I broke the FPC cable that connects the LCD to the Main board do you know the part number or where to buy it?
Thanks in advance
Eric Alba - 답글
Thanks so much! It was really helpful! One screen hinge on my nx500 was loose because the two screws holding it came off. They were loose inside the case, and eventually stuck to the magnet on the back of the speaker. So it was easy to find them and screw them back again. My camera is like new again! Keep up the good work!
radughici - 답글
I’m sorry, but you forgot the last several steps on how to remove the old screen from the screen assembly. One can only find the actual screen replacements for sale, not the whole screen assembly.
ppeterson - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 22
전체 시간: 2,474
