주요 콘텐츠로 건너뛰기
Samsung NX500 Screen Side Encasement Replacement
필요한 것
  1. Samsung NX500 Screen Side Encasement Replacement, Battery: 1 단계, 이미지 2개 중 1개 Samsung NX500 Screen Side Encasement Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Pull the switch on the bottom of the camera back with your thumb.
  2. Samsung NX500 Screen Side Encasement Replacement: 2 단계, 이미지 2개 중 1개 Samsung NX500 Screen Side Encasement Replacement: 2 단계, 이미지 2개 중 2개
    • Push second switch(blue) forward with your thumb.
  3. Samsung NX500 Screen Side Encasement Replacement: 3 단계, 이미지 1개 중 1개
    • Pull out battery.
  4. Samsung NX500 Screen Side Encasement Replacement, Screen Side Encasement: 4 단계, 이미지 3개 중 1개 Samsung NX500 Screen Side Encasement Replacement, Screen Side Encasement: 4 단계, 이미지 3개 중 2개 Samsung NX500 Screen Side Encasement Replacement, Screen Side Encasement: 4 단계, 이미지 3개 중 3개
    • Open the screen exposing the hinge cover and place the plastic opening tool inside.
    • Pry the hinge cover up by moving the plastic opening tool in a downward motion.
    • Remove the black 4mm Phillips #000 screw that is revealed once the hinge cover is removed.
  5. Samsung NX500 Screen Side Encasement Replacement: 5 단계, 이미지 3개 중 1개 Samsung NX500 Screen Side Encasement Replacement: 5 단계, 이미지 3개 중 2개 Samsung NX500 Screen Side Encasement Replacement: 5 단계, 이미지 3개 중 3개
    • Unscrew the two 4 mm Phillips #000 screws on the right hand side of the camera using the screwdriver.
    • Unscrew five more 4 mm Phillips #000 screws that are located at the bottom of the camera with the screwdriver.
    • In the second step, do not the remove the two 4 mm Phillips #000 screen on the screen.
    • Remove the last exterior 4 mm Phillips #000 screws on the left hand side of the camera with the scredriver.
  6. Samsung NX500 Screen Side Encasement Replacement: 6 단계, 이미지 2개 중 1개 Samsung NX500 Screen Side Encasement Replacement: 6 단계, 이미지 2개 중 2개
    • Use the plastic opening tool in a downward motion around each side of the camera to pry the casing open.
    • The casing should be removed easily; you shouldn't have to use much force.
  7. Samsung NX500 Screen Side Encasement Replacement: 7 단계, 이미지 2개 중 1개 Samsung NX500 Screen Side Encasement Replacement: 7 단계, 이미지 2개 중 2개
    • Locate the black ribbon at the bottom left of the camera's interior.
    • Place the plastic opening tool under the black ribbon connector.
    • Remove the cable by moving your plastic opening tool in a downward motion.
    • There is zero to little force needed to remove this ribbon.
결론
작성자
3다른 기여자 명과 함께
carter grenewicz
회원 가입일: 09/15/16
204 평판
안내서 2개를 작성함
USF Tampa, Team 18-5, Blackwell Fall 2016 USF Tampa, Team 18-5, Blackwell Fall 2016 회원
USFT-BLACKWELL-F16S18G5
3 회원들
안내서 12개를 작성함
1가이드 댓글
your dumb. idot
Nick Furio - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 4
지난 30일: 14
전체 시간: 1,133
