주요 콘텐츠로 건너뛰기
Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement
필요한 것
  1. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement, Battery: 1 단계, 이미지 1/1
    • Flip your laptop over so that the back is face up.
  2. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: 2 단계, 이미지 1/2 Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: 2 단계, 이미지 2/2
    • Use a Phillips #00 screwdriver to remove the four 6.5mm screws and the six 4.5mm screws that secure the back plate.
  3. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: 3 단계, 이미지 1/2 Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: 3 단계, 이미지 2/2
    • Use a plastic opening tool to remove the back plate from the laptop.
    • It is recommended that you start from a corner then run the tool along the edge of the back plate.
  4. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: 4 단계, 이미지 1/2 Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: 4 단계, 이미지 2/2
    • Use a Phillips #00 screwdriver to remove the three 4.5 mm screws holding the battery in place.
  5. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: 5 단계, 이미지 1/3 Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: 5 단계, 이미지 2/3 Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: 5 단계, 이미지 3/3
    • Use a spudger to pry the battery connecting cable from the laptop and remove the battery.
    • Using the metal spudger may severely damage the internal components in your device.
  6. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement, Hard Drive and SSD: 6 단계, 이미지 1/1
    • Remove the connection cable from the hard drive.
  7. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: 7 단계, 이미지 1/1
    • Use a Phillips #00 to remove four screws from the hard drive cradle.
  8. Samsung Notebook 7 Spin NP740U3MK01US Hard Drive and SSD Replacement: 8 단계, 이미지 1/1
    • Pull the hard drive away from the cradle and remove it from the device.
결론
Minje Sa
회원 가입일: 09/16/19
113 평판
안내서 1개 작성함
댓글 2개
Would you point out where the SSD slot would be?
aroyphillips - 답글
this was very helpfull!, im not sure where i could find the SSD though
Kaleb Miller - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 54
전체 시간: 3,330
