주요 콘텐츠로 건너뛰기
Samsung Notebook 7 Spin NP740U3MK01US RAM Replacement
필요한 것
  1. Samsung Notebook 7 Spin NP740U3MK01US RAM Replacement, Battery: 1 단계, 이미지 1/1
    • Flip your laptop over so that the back is face up.
  2. Samsung Notebook 7 Spin NP740U3MK01US RAM Replacement: 2 단계, 이미지 1/2 Samsung Notebook 7 Spin NP740U3MK01US RAM Replacement: 2 단계, 이미지 2/2
    • Use a Phillips #00 screwdriver to remove the four 6.5mm screws and the six 4.5mm screws that secure the back plate.
  3. Samsung Notebook 7 Spin NP740U3MK01US RAM Replacement: 3 단계, 이미지 1/2 Samsung Notebook 7 Spin NP740U3MK01US RAM Replacement: 3 단계, 이미지 2/2
    • Use a plastic opening tool to remove the back plate from the laptop.
    • It is recommended that you start from a corner then run the tool along the edge of the back plate.
  4. Samsung Notebook 7 Spin NP740U3MK01US RAM Replacement: 4 단계, 이미지 1/2 Samsung Notebook 7 Spin NP740U3MK01US RAM Replacement: 4 단계, 이미지 2/2
    • Use a Phillips #00 screwdriver to remove the three 4.5 mm screws holding the battery in place.
  5. Samsung Notebook 7 Spin NP740U3MK01US RAM Replacement: 5 단계, 이미지 1/3 Samsung Notebook 7 Spin NP740U3MK01US RAM Replacement: 5 단계, 이미지 2/3 Samsung Notebook 7 Spin NP740U3MK01US RAM Replacement: 5 단계, 이미지 3/3
    • Use a spudger to pry the battery connecting cable from the laptop and remove the battery.
    • Using the metal spudger may severely damage the internal components in your device.
  6. Samsung Notebook 7 Spin NP740U3MK01US RAM Replacement, RAM: 6 단계, 이미지 1/2 Samsung Notebook 7 Spin NP740U3MK01US RAM Replacement, RAM: 6 단계, 이미지 2/2
    • Use the Phillips #00 screwdriver to remove the five 4.5 mm screws.
  7. Samsung Notebook 7 Spin NP740U3MK01US RAM Replacement: 7 단계, 이미지 1/2 Samsung Notebook 7 Spin NP740U3MK01US RAM Replacement: 7 단계, 이미지 2/2
    • Push these clamps outwards away from the RAM. The RAM should pop out.
    • Remove the RAM from the device. Repeat the same step for any additional RAM.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
William Edwards
회원 가입일: 09/16/19
153 평판
안내서 1개 작성함
댓글 한 개
If my laptop already has 12 GB of RAM, is it possible to increase it to 24 GB? what would the limit be? I have read somewhere else it is 12 GB.
In that case, would the remaining slot be useless, or does my laptop come with two 6 GB RAM boards, one for each slot
David Hijar - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 23
전체 시간: 1,107
