주요 콘텐츠로 건너뛰기
Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement
필요한 것
  1. Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement, Battery: 1 단계, 이미지 1/1
    • Flip your laptop over so that the back is face up.
  2. Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: 2 단계, 이미지 1/2 Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: 2 단계, 이미지 2/2
    • Use a Phillips #00 screwdriver to remove the four 6.5mm screws and the six 4.5mm screws that secure the back plate.
  3. Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: 3 단계, 이미지 1/2 Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: 3 단계, 이미지 2/2
    • Use a plastic opening tool to remove the back plate from the laptop.
    • It is recommended that you start from a corner then run the tool along the edge of the back plate.
  4. Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: 4 단계, 이미지 1/2 Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: 4 단계, 이미지 2/2
    • Use a Phillips #00 screwdriver to remove the three 4.5 mm screws holding the battery in place.
  5. Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: 5 단계, 이미지 1/3 Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: 5 단계, 이미지 2/3 Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: 5 단계, 이미지 3/3
    • Use a spudger to pry the battery connecting cable from the laptop and remove the battery.
    • Using the metal spudger may severely damage the internal components in your device.
  6. Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement, Wi-Fi Card: 6 단계, 이미지 1/3 Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement, Wi-Fi Card: 6 단계, 이미지 2/3 Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement, Wi-Fi Card: 6 단계, 이미지 3/3
    • Use the Phillips #00 screwdriver to remove the two 4.5mm screws holding the cover plate in place.
  7. Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: 7 단계, 이미지 1/2 Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: 7 단계, 이미지 2/2
    • Remove the black ribbon cable by pulling up on the black cover and sliding out the cable.
  8. Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: 8 단계, 이미지 1/3 Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: 8 단계, 이미지 2/3 Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: 8 단계, 이미지 3/3
    • Remove the three black and white cables by gently pulling on them.
  9. Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: 9 단계, 이미지 1/2 Samsung Notebook 7 Spin NP740U3MK01US Wi-Fi Card Replacement: 9 단계, 이미지 2/2
    • Use the Phillips #00 screwdriver to remove the two 4.5mm screws holding the USB board down and remove the board.
결론
Alexander Ulman
회원 가입일: 09/16/19
394 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 11
전체 시간: 720
