주요 콘텐츠로 건너뛰기
Samsung Odyssey NP800G5M Fan Replacement
필요한 것
  1. Samsung Odyssey NP800G5M Fan Replacement, Battery: 1 단계, 이미지 1/1
    • Remove the eleven 6.6 mm screws on the back of the computer using the Phillips #0 screwdriver.
  2. Samsung Odyssey NP800G5M Fan Replacement: 2 단계, 이미지 1/2 Samsung Odyssey NP800G5M Fan Replacement: 2 단계, 이미지 2/2
    • Using the opening tool, gently pry apart the back corners until the plastic separates from the body of the laptop.
    • Work your way around the body of the laptop until the back cover is completely separated.
    • Remove the back casing.
  3. Samsung Odyssey NP800G5M Fan Replacement: 3 단계, 이미지 1/2 Samsung Odyssey NP800G5M Fan Replacement: 3 단계, 이미지 2/2
    • Disconnect the battery connector cable.
    • Working on the device without removing the battery connector cable can damage major components of the device.
  4. Samsung Odyssey NP800G5M Fan Replacement: 4 단계, 이미지 1/3 Samsung Odyssey NP800G5M Fan Replacement: 4 단계, 이미지 2/3 Samsung Odyssey NP800G5M Fan Replacement: 4 단계, 이미지 3/3
    • Remove the four 6.6 mm screws using the Phillips #0 screwdriver.
    • Remove the battery from the device.
  5. Samsung Odyssey NP800G5M Fan Replacement, Fan: 5 단계, 이미지 1/3 Samsung Odyssey NP800G5M Fan Replacement, Fan: 5 단계, 이미지 2/3 Samsung Odyssey NP800G5M Fan Replacement, Fan: 5 단계, 이미지 3/3
    • Disconnect the fans from the motherboard by pulling the plugs away from their connectors.
    • Using the Phillips #0 screwdriver, remove the four 4.6mm screws.
    • Using the same screwdriver, unscrew the six screws surrounding the heat sink.
    • These screws cannot be removed from the device.
    • Remove the fan assembly from the device.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Sean Surrency
회원 가입일: 09/16/19
807 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 17
전체 시간: 1,225
