소개
Laptops overheating has been a prevalent problem since their conception. The usual culprit of this can be attributed to a broken or slow ventilation system. The Samsung Odyssey uses the HexaFlow cooling system to prevent overheating, but issues can still arise. This guide will show you how to replace the fan in your laptop.
필요한 것
Remove the eleven 6.6 mm screws on the back of the computer using the Phillips #0 screwdriver.
다른 4명이 해당 안내서를 완성하였습니다.
