주요 콘텐츠로 건너뛰기
Samsung PL20 LCD Replacement
필요한 것
  1. Samsung PL20 LCD Replacement, LCD: 1 단계, 이미지 1/3 Samsung PL20 LCD Replacement, LCD: 1 단계, 이미지 2/3 Samsung PL20 LCD Replacement, LCD: 1 단계, 이미지 3/3
    • Here is the broken LCD. The spider crack in the glass, as well as the discoloration of the screen, is clearly visible.
    • Remove the battery and the memory card from the device, if so equipped.
    • Remove the two screws on the left side.
  2. Samsung PL20 LCD Replacement: 2 단계, 이미지 1/3 Samsung PL20 LCD Replacement: 2 단계, 이미지 2/3 Samsung PL20 LCD Replacement: 2 단계, 이미지 3/3
    • Remove one screw from the bottom
    • Remove the two screws on the right side.
    • Use a plastic opening tool, or your fingernails, to split the casing apart. Start from the battery compartment and work your way around the case. The case should split easily.
  3. Samsung PL20 LCD Replacement: 3 단계, 이미지 1/3 Samsung PL20 LCD Replacement: 3 단계, 이미지 2/3 Samsung PL20 LCD Replacement: 3 단계, 이미지 3/3
    • Once the back of the case is removed, the LCD becomes immediately visible.
    • Remove the LCD from its holder to gain access to the connector.
    • Open the connector, and flip the black clip upwards, freeing the LCD. It can now be removed and the new one installed.
결론
다른 6명이 해당 안내서를 완성하였습니다.
oldturkey03
회원 가입일: 09/29/10
782,216 평판
안내서 119개 작성하였습니다
Global Fixers Global Fixers 회원
Community
33 회원들
안내서 537개 작성하였습니다
댓글 한 개
Great help! Screen replaced no problem. Thank you
EE61 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 31
전체 시간: 3,499
