주요 콘텐츠로 건너뛰기
Samsung PL20 Lens Replacement
필요한 것
  1. Samsung PL20 Lens Replacement, Lens: 1 단계, 이미지 1/3 Samsung PL20 Lens Replacement, Lens: 1 단계, 이미지 2/3 Samsung PL20 Lens Replacement, Lens: 1 단계, 이미지 3/3
    • Remove the battery and the memory card from the device.
    • Remove the two screws on the side of the device, to the left of the camera lens.
  2. Samsung PL20 Lens Replacement: 2 단계, 이미지 1/3 Samsung PL20 Lens Replacement: 2 단계, 이미지 2/3 Samsung PL20 Lens Replacement: 2 단계, 이미지 3/3
    • Remove the single screw from the bottom of the device.
    • Remove the two screws on the side of the the device, to the right of the camera lens.
    • Using a plastic opening tool, pry the outside casing apart. Start from the battery compartment and work around the seem of the casing.
  3. Samsung PL20 Lens Replacement: 3 단계, 이미지 1/3 Samsung PL20 Lens Replacement: 3 단계, 이미지 2/3 Samsung PL20 Lens Replacement: 3 단계, 이미지 3/3
    • Remove the back panel, revealing the LCD screen.
    • Pull the LCD screen out of its holder. Once you have access to the connecting strip, flip the clip upwards releasing the screen completely and remove.
  4. Samsung PL20 Lens Replacement: 4 단계, 이미지 1/3 Samsung PL20 Lens Replacement: 4 단계, 이미지 2/3 Samsung PL20 Lens Replacement: 4 단계, 이미지 3/3
    • Gently pull the front panel from the device.
    • Remove the two screws attaching the LCD screen holder to the device.
    • Remove the screen holder from the rest of the device.
  5. Samsung PL20 Lens Replacement: 5 단계, 이미지 1/3 Samsung PL20 Lens Replacement: 5 단계, 이미지 2/3 Samsung PL20 Lens Replacement: 5 단계, 이미지 3/3
    • Flip the grey clip upwards, releasing the connector from the device.
    • Disconnect the ribbon cable extending from the left side.
    • Disconnect the ribbon cable extending from the button bar.
    • Remove the 2 screws.
  6. Samsung PL20 Lens Replacement: 6 단계, 이미지 1/3 Samsung PL20 Lens Replacement: 6 단계, 이미지 2/3 Samsung PL20 Lens Replacement: 6 단계, 이미지 3/3
    • Remove these 3 screws. releasing the lens from the logic board.
    • Remove the lens from the logic board.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
oldturkey03
회원 가입일: 09/29/10
782,258 평판
안내서 119개 작성하였습니다
Global Fixers Global Fixers 회원
Community
33 회원들
안내서 537개 작성하였습니다
댓글 한 개
Beware there is a capacitor that stores a charge even when the battery is removed. On my camera i touched it, it created a short circuit, i got a shock, and it killed my camera.
morrisettema - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 11
전체 시간: 3,035
