주요 콘텐츠로 건너뛰기
Samsung PL200 SD card Replacement
  1. Samsung PL200 SD card Replacement, SD card: 1 단계, 이미지 1/2 Samsung PL200 SD card Replacement, SD card: 1 단계, 이미지 2/2
    • Flip Samsung PL200 over to access battery/SD card compartment on the bottom. There is a sliding release button (labeled 'OPEN') that can be slid sideways to open the battery/SD card compartment.
    • Slide this button in the direction that the arrow is pointing to release and open the spring loaded battery/sd compartment door.
    • Once opened, the SD card should be visible.
  2. Samsung PL200 SD card Replacement: 2 단계, 이미지 1/2 Samsung PL200 SD card Replacement: 2 단계, 이미지 2/2
    • Once the battery/SD card compartment is opened, simply push the SD card down to activate the spring loaded ejector.
    • This will cause the SD card to raise up enough to allow you to grab it with your fingers.
    • Use your fingers to remove the old SD card.
  3. Samsung PL200 SD card Replacement: 3 단계, 이미지 1/2 Samsung PL200 SD card Replacement: 3 단계, 이미지 2/2
    • Insert the new SD card into the SD card slot.
    • Make sure to push it down all the way until it clicks and remains flush with battery.
    • Close the battery/SD card compartment.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jacob Presnell
회원 가입일: 01/29/15
219 평판
안내서 2개 작성하였습니다
Clemson, Team 15-7, Shirley Winter 2015 Clemson, Team 15-7, Shirley Winter 2015 회원
CLEM-SHIRLEY-W15S15G7
5 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 6
전체 시간: 244
