주요 콘텐츠로 건너뛰기
Samsung POWERbot R7070 Power Brush Replacement
  1. Samsung POWERbot R7070 Power Brush Replacement, Brush: 1 단계, 이미지 1/1
    • Flip the device over to access the bottom of the vacuum with the brush compartment positioned close to you.
  2. Samsung POWERbot R7070 Power Brush Replacement: 2 단계, 이미지 1/1
    • Slide up on the two yellow sliding tabs to unlock the brush compartment.
  3. Samsung POWERbot R7070 Power Brush Replacement: 3 단계, 이미지 1/3 Samsung POWERbot R7070 Power Brush Replacement: 3 단계, 이미지 2/3 Samsung POWERbot R7070 Power Brush Replacement: 3 단계, 이미지 3/3
    • Press down on the outer edge of the brush cover to tilt the brush cover up. Grab the newly exposed inner edge and lift out the brush cover.
  4. Samsung POWERbot R7070 Power Brush Replacement: 4 단계, 이미지 1/2 Samsung POWERbot R7070 Power Brush Replacement: 4 단계, 이미지 2/2
    • Pull up the left side of the brush and lift out of the brush compartment.
    • When replacing the brush, the square peg on the right end of the brush must be correctly oriented with the square hole on the right end of the brush compartment.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Christine Erdtsieck
회원 가입일: 09/11/17
439 평판
안내서 1개 작성함
CSU Fullerton, Team S2-G8, Bruce Fall 2017 CSU Fullerton, Team S2-G8, Bruce Fall 2017 회원
CSUF-BRUCE-F17S2G8
3 회원들
안내서 10개 작성하였습니다
댓글 5개
How often should the power VR 7000 series self cleaning powerbrush be replace?
Kip Williams - 답글
Hello, where could I find a replacement brush for this model?
Haitham - 답글
Without a part number, I cannot find a replacement brush.
David Williams - 답글
Your brush motor is broken and you can't find it?
engine model: RS395 - 2175 metal case,
fixxer - 답글
Hi, Can anyone send me some info on a part number and where to get a replacement brush ~ Samsung POWERbot R7070 Power Brush Replacement?
Thanks much
Kokko Walker - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 24
전체 시간: 4,108
