주요 콘텐츠로 건너뛰기
Samsung POWERbot R7070 Right Driving Wheel Replacement
필요한 것
  1. Samsung POWERbot R7070 Right Driving Wheel Replacement, Battery: 1 단계, 이미지 1/1
    • Turn the emergency switch off.
  2. Samsung POWERbot R7070 Right Driving Wheel Replacement: 2 단계, 이미지 1/2 Samsung POWERbot R7070 Right Driving Wheel Replacement: 2 단계, 이미지 2/2
    • Remove the two exposed screws on the top right of the device.
  3. Samsung POWERbot R7070 Right Driving Wheel Replacement: 3 단계, 이미지 1/1
    • Lift the cover plate to expose the battery.
  4. Samsung POWERbot R7070 Right Driving Wheel Replacement: 4 단계, 이미지 1/2 Samsung POWERbot R7070 Right Driving Wheel Replacement: 4 단계, 이미지 2/2
    • Using one hand, pinch the white plastic connector where the battery's wiring connects the POWERbot. Pull up to disconnect.
  5. Samsung POWERbot R7070 Right Driving Wheel Replacement: 5 단계, 이미지 1/2 Samsung POWERbot R7070 Right Driving Wheel Replacement: 5 단계, 이미지 2/2
    • Lift the battery from the right side, up and out of its compartment.
  6. Samsung POWERbot R7070 Right Driving Wheel Replacement, Motor: 6 단계, 이미지 1/2 Samsung POWERbot R7070 Right Driving Wheel Replacement, Motor: 6 단계, 이미지 2/2
    • Unscrew the two silver 1.5 cm screws on the left and right side of the battery compartment.
    • Remove the two 1.5 cm screws above the yellow sliding lock tabs.
    • Remove the two 1.2 cm screws in the brush compartment.
  7. Samsung POWERbot R7070 Right Driving Wheel Replacement: 7 단계, 이미지 1/2 Samsung POWERbot R7070 Right Driving Wheel Replacement: 7 단계, 이미지 2/2
    • With moderate force, separate the silver top from the black bottom of the vacuum.
    • The cover will only separate a few inches as the two halves are connected by wires.
  8. Samsung POWERbot R7070 Right Driving Wheel Replacement: 8 단계, 이미지 1/1
    • Disconnect the white and red wired connector attached to the top half of the base of the vacuum by squeezing the connector and pulling up.
  9. Samsung POWERbot R7070 Right Driving Wheel Replacement: 9 단계, 이미지 1/1
    • Pinching the top and bottom of the black wired connector, pull outward, fully detaching the top from the bottom of the device.
  10. Samsung POWERbot R7070 Right Driving Wheel Replacement: 10 단계, 이미지 1/1
    • Detach the wide circuit connector on the left side by pinching and pressing down on the right and left side of the clip, pulling the connector out.
    • Pull the connector out by the left and right side of the white clip and not by the wires.
  11. Samsung POWERbot R7070 Right Driving Wheel Replacement: 11 단계, 이미지 1/2 Samsung POWERbot R7070 Right Driving Wheel Replacement: 11 단계, 이미지 2/2
    • Remove the four 1.2 cm screws.
    • Remove the single 0.8 cm screw.
  12. Samsung POWERbot R7070 Right Driving Wheel Replacement: 12 단계, 이미지 1/1
    • Remove the two 1.5 cm screws on the motor chamber.
  13. Samsung POWERbot R7070 Right Driving Wheel Replacement: 13 단계, 이미지 1/2 Samsung POWERbot R7070 Right Driving Wheel Replacement: 13 단계, 이미지 2/2
    • Lift the motor by grabbing the body of the motor, lifting upward.
    • With the screws removed from the motor chamber the top of the motor chamber will pop open.
  14. Samsung POWERbot R7070 Right Driving Wheel Replacement, Right Driving Wheel: 14 단계, 이미지 1/2 Samsung POWERbot R7070 Right Driving Wheel Replacement, Right Driving Wheel: 14 단계, 이미지 2/2
    • With the spring fully retracted, unhook the spring from the wheel casing.
  15. Samsung POWERbot R7070 Right Driving Wheel Replacement: 15 단계, 이미지 1/2 Samsung POWERbot R7070 Right Driving Wheel Replacement: 15 단계, 이미지 2/2
    • Remove the screw securing the black plastic piece to the right of the wheel casing.
    • This piece is not part of the wheel casing but must be unscrewed to remove the wheel casing.
    • Lift wheel and wheel casing out of vacuum base.
  16. Samsung POWERbot R7070 Right Driving Wheel Replacement: 16 단계, 이미지 1/2 Samsung POWERbot R7070 Right Driving Wheel Replacement: 16 단계, 이미지 2/2
    • Remove the three screws fastening the two halves of the wheel casing together.
  17. Samsung POWERbot R7070 Right Driving Wheel Replacement: 17 단계, 이미지 1/2 Samsung POWERbot R7070 Right Driving Wheel Replacement: 17 단계, 이미지 2/2
    • Separate the unsecured half of the wheel casing, exposing the wheel.
  18. Samsung POWERbot R7070 Right Driving Wheel Replacement: 18 단계, 이미지 1/1
    • Remove the three screws on the remaining half of the wheel casing.
  19. Samsung POWERbot R7070 Right Driving Wheel Replacement: 19 단계, 이미지 1/3 Samsung POWERbot R7070 Right Driving Wheel Replacement: 19 단계, 이미지 2/3 Samsung POWERbot R7070 Right Driving Wheel Replacement: 19 단계, 이미지 3/3
    • Unscrew the black 1 cm screw securing the center of the wheel.
    • Remove the wheel.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Lauren Nubla
회원 가입일: 09/11/17
289 평판
안내서 2개 작성하였습니다
CSU Fullerton, Team S2-G8, Bruce Fall 2017 CSU Fullerton, Team S2-G8, Bruce Fall 2017 회원
CSUF-BRUCE-F17S2G8
3 회원들
안내서 10개 작성하였습니다
댓글 3개
Where can you find the replacement left driving wheel? are all the model the same?
ghvolleyball - 답글
Very helpful, thank you.
Just beware of the rubber vacuum part and it’s placement after taking apart the vacuum.
James MacKenzie - 답글
Very clear and helpful. Thank you
Able to replace the wheel quickly. Did not need to do steps 16-19 because new part came complete with new wheel.
Andy - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 13
전체 시간: 1,606
