주요 콘텐츠로 건너뛰기
Samsung POWERbot R7070 Vacuum Motor Replacement
필요한 것
  1. Samsung POWERbot R7070 Vacuum Motor Replacement, Battery: 1 단계, 이미지 1/1
    • Turn the emergency switch off.
  2. Samsung POWERbot R7070 Vacuum Motor Replacement: 2 단계, 이미지 1/2 Samsung POWERbot R7070 Vacuum Motor Replacement: 2 단계, 이미지 2/2
    • Remove the two exposed screws on the top right of the device.
  3. Samsung POWERbot R7070 Vacuum Motor Replacement: 3 단계, 이미지 1/1
    • Lift the cover plate to expose the battery.
  4. Samsung POWERbot R7070 Vacuum Motor Replacement: 4 단계, 이미지 1/2 Samsung POWERbot R7070 Vacuum Motor Replacement: 4 단계, 이미지 2/2
    • Using one hand, pinch the white plastic connector where the battery's wiring connects the POWERbot. Pull up to disconnect.
  5. Samsung POWERbot R7070 Vacuum Motor Replacement: 5 단계, 이미지 1/2 Samsung POWERbot R7070 Vacuum Motor Replacement: 5 단계, 이미지 2/2
    • Lift the battery from the right side, up and out of its compartment.
  6. Samsung POWERbot R7070 Vacuum Motor Replacement, Motor: 6 단계, 이미지 1/2 Samsung POWERbot R7070 Vacuum Motor Replacement, Motor: 6 단계, 이미지 2/2
    • Unscrew the two silver 1.5 cm screws on the left and right side of the battery compartment.
    • Remove the two 1.5 cm screws above the yellow sliding lock tabs.
    • Remove the two 1.2 cm screws in the brush compartment.
  7. Samsung POWERbot R7070 Vacuum Motor Replacement: 7 단계, 이미지 1/2 Samsung POWERbot R7070 Vacuum Motor Replacement: 7 단계, 이미지 2/2
    • With moderate force, separate the silver top from the black bottom of the vacuum.
    • The cover will only separate a few inches as the two halves are connected by wires.
  8. Samsung POWERbot R7070 Vacuum Motor Replacement: 8 단계, 이미지 1/1
    • Disconnect the white and red wired connector attached to the top half of the base of the vacuum by squeezing the connector and pulling up.
  9. Samsung POWERbot R7070 Vacuum Motor Replacement: 9 단계, 이미지 1/1
    • Pinching the top and bottom of the black wired connector, pull outward, fully detaching the top from the bottom of the device.
  10. Samsung POWERbot R7070 Vacuum Motor Replacement: 10 단계, 이미지 1/1
    • Detach the wide circuit connector on the left side by pinching and pressing down on the right and left side of the clip, pulling the connector out.
    • Pull the connector out by the left and right side of the white clip and not by the wires.
  11. Samsung POWERbot R7070 Vacuum Motor Replacement: 11 단계, 이미지 1/2 Samsung POWERbot R7070 Vacuum Motor Replacement: 11 단계, 이미지 2/2
    • Remove the four 1.2 cm screws.
    • Remove the single 0.8 cm screw.
  12. Samsung POWERbot R7070 Vacuum Motor Replacement: 12 단계, 이미지 1/1
    • Remove the two 1.5 cm screws on the motor chamber.
  13. Samsung POWERbot R7070 Vacuum Motor Replacement: 13 단계, 이미지 1/2 Samsung POWERbot R7070 Vacuum Motor Replacement: 13 단계, 이미지 2/2
    • Lift the motor by grabbing the body of the motor, lifting upward.
    • With the screws removed from the motor chamber the top of the motor chamber will pop open.
결론
다른 8명이 해당 안내서를 완성하였습니다.
Eric Anderson
회원 가입일: 09/11/17
465 평판
안내서 2개 작성하였습니다
CSU Fullerton, Team S2-G8, Bruce Fall 2017 CSU Fullerton, Team S2-G8, Bruce Fall 2017 회원
CSUF-BRUCE-F17S2G8
3 회원들
안내서 10개 작성하였습니다
댓글 6개
Anybody know where I can get the motor?
donstatus87 - 답글
I'm getting a Power brush error. Does the motor contain the power brush square socket and gearing?
Steve.
Steven Nicholas - 답글
One can actually open up the motor housing and take out the metal motor. Be careful not to break the clips when opening the housing… because I did…. but duct tape will prolly hold it together again. Anyway , the motor bears the following markings in my R7040: VCM-140CLDA DC21.6V 145W 2018.5.22-12.50
Have fun!
websites140 - 답글
Easy to replace and found a refurbished motor on eBay.
David Trinkle - 답글
Thanks for this guide! My motor was making a high pitched whine and grind - bought a replacement refurb motor on eBay for $39; hope it works.
joey - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 26
전체 시간: 4,046
