소개
This guide will teach you how to replace the vacuum motor of your POWERbot. This can be done to restore the suction strength of the vacuum.
필요한 것
Slide the plastic opening tool to the left, remaining under the black cover, until two left side pins have been detached. Then slide the plastic opening tool to the right until two right side pins have been detached.
Grab the two clips near the front of the black cover, on in front of each wheel. Pull the clips away from the wheels.
Remove the three 5mm Phillips #1 screws in the holes around the vacuum motor.
다른 8명이 해당 안내서를 완성하였습니다.
