주요 콘텐츠로 건너뛰기
Samsung Portable Dualband Tri-Mode Internal Speaker Replacement
필요한 것
  1. Samsung Portable Dualband Tri-Mode Internal Speaker Replacement, Battery: 1 단계, 이미지 1/2 Samsung Portable Dualband Tri-Mode Internal Speaker Replacement, Battery: 1 단계, 이미지 2/2
    • Slide the battery out from the battery compartment on the back of the phone.
  2. Samsung Portable Dualband Tri-Mode Internal Speaker Replacement, Antenna: 2 단계, 이미지 1/2 Samsung Portable Dualband Tri-Mode Internal Speaker Replacement, Antenna: 2 단계, 이미지 2/2
    • Unscrew the antenna top.
  3. Samsung Portable Dualband Tri-Mode Internal Speaker Replacement: 3 단계, 이미지 1/3 Samsung Portable Dualband Tri-Mode Internal Speaker Replacement: 3 단계, 이미지 2/3 Samsung Portable Dualband Tri-Mode Internal Speaker Replacement: 3 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Clasp the antenna with tweezers and push toward the top.
    • Remove the antenna.
  4. Samsung Portable Dualband Tri-Mode Internal Speaker Replacement, Backplate: 4 단계, 이미지 1/3 Samsung Portable Dualband Tri-Mode Internal Speaker Replacement, Backplate: 4 단계, 이미지 2/3 Samsung Portable Dualband Tri-Mode Internal Speaker Replacement, Backplate: 4 단계, 이미지 3/3
    • Remove the four screws (3 mm) from the battery compartment.
    • Press the release buttons located on the side of the phone while gently prying the back plate off.
  5. Samsung Portable Dualband Tri-Mode Internal Speaker Replacement, Motherboard: 5 단계, 이미지 1/3 Samsung Portable Dualband Tri-Mode Internal Speaker Replacement, Motherboard: 5 단계, 이미지 2/3 Samsung Portable Dualband Tri-Mode Internal Speaker Replacement, Motherboard: 5 단계, 이미지 3/3
    • Press the release tabs on the sides of the back casing.
    • Gently pry the motherboard loose and remove it.
  6. Samsung Portable Dualband Tri-Mode Internal Speaker Replacement, Internal Speaker: 6 단계, 이미지 1/3 Samsung Portable Dualband Tri-Mode Internal Speaker Replacement, Internal Speaker: 6 단계, 이미지 2/3 Samsung Portable Dualband Tri-Mode Internal Speaker Replacement, Internal Speaker: 6 단계, 이미지 3/3
    • At the front plate of the phone, locate the internal speaker unit at the top of the front plate.
    • Pry the internal speaker away from the front casing of the phone using a flathead screwdriver.
    • Remove the internal speaker from the front casing.
결론
Barbara
회원 가입일: 03/26/14
413 평판
안내서 4개 작성하였습니다
Clemson, Team 6-2, Benson Spring 2014 Clemson, Team 6-2, Benson Spring 2014 회원
CLEM-BENSON-S14S6G2
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 13
전체 시간: 247
