이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Slide the battery out from the battery compartment on the back of the phone.
이 단계에 사용된 도구:Tweezers$4.99-
Clasp the antenna with tweezers and push toward the top.
Remove the antenna.
Remove the four screws (3 mm) from the battery compartment.
Press the release buttons located on the side of the phone while gently prying the back plate off.
Press the release tabs on the sides of the back casing.
Gently pry the motherboard loose and remove it.
Remove the black keypad from the phone casing.
Clean the keypad and check for any damage. If the keypad is damaged, then replace it with a new one.
