이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Many problems with the functionality of the phone may arise that are beyond a simple battery change, in which case means that the motherboard of the phone may have been compromised. If the screen or the keypad buttons do not work, it is possible that changing the motherboard will directly solve the problem. This guide shows how to access and replace the motherboard of the phone.
필요한 것
Remove the four screws (3 mm) from the battery compartment.
Press the release buttons located on the side of the phone while gently prying the back plate off.
Press the release tabs on the sides of the back casing.
Gently pry the motherboard loose and remove it.
다른 한 분이 해당 안내서를 완성하였습니다.
