주요 콘텐츠로 건너뛰기
Samsung Propel SIM Card Replacement
필요한 것
  1. Samsung Propel SIM Card Replacement, SIM Card: 1 단계, 이미지 1/2 Samsung Propel SIM Card Replacement, SIM Card: 1 단계, 이미지 2/2
    • On the back of the phone locate the back panel.
    • Remove the back panel.
    • Then locate the battery, remove the battery. You can set it to the side for now.
  2. Samsung Propel SIM Card Replacement: 2 단계, 이미지 1/2 Samsung Propel SIM Card Replacement: 2 단계, 이미지 2/2
    • Find the spot for the SIM Card; on the bottom right as seen in the picture.
    • Then remove the old sim card by sliding it out.
    • Now you can insert a new sim card in slot where the old one was.
  3. Samsung Propel SIM Card Replacement: 3 단계, 이미지 1/1
    • Finally, insert the battery back to its original location.
    • Then place the back panel.
결론
James Cote
회원 가입일: 11/05/15
322 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 1-4, Bhusal Fall 2015 UMass Dartmouth, Team 1-4, Bhusal Fall 2015 회원
UMASSD-BHUSAL-F15S1G4
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 15
전체 시간: 221
